MSD 8572 Distributor Tuning Question
Old Mar 2, 2010 | 11:08 PM
tbomb69's Avatar
tbomb69
6th Gear
Default MSD 8572 Distributor Tuning Question
Has anyone messed with the springs/bushings for getting the right timing curve for a 350? I know this depends on the specific setup of the motor. I've got the basic ones in that came installed in the distributor, and am looking for guidance on how to start troubleshooting different spring/bushing combos to tune the engine correctly. It runs fine without pinging but doesn't feel like it's putting out the power it should. Any tips would be helpful.
Old Mar 2, 2010 | 11:29 PM
bigvette1's Avatar
bigvette1
Here is what to do.
1. Go to MSDIGNITION.COM and download the instrutions for setup of the Dist you have. This will cover the curves for springs and the total advance by the bushings. Very easy to change.
2. Send me your email address and I'll send you copies of Lar's info papers on timing etc. They will walk you through timing a chevy engine.
PS - You want the total timing "all in" by 2500 - 3000 rpm's and a total advance of 36 degrees. Start checking yours out as to what you have.
Old Mar 3, 2010 | 09:52 AM
08vycpe's Avatar
08vycpe
Keep in mind that when people talk of total timing they mean base timing + mechanical advance and NOT including vacuum advance. Keep the vacuum line disconnected and plugged when checking total timing. The reason is that under WOT the vacuum advance isn't functioning due to the low vacuum at WOT.
Old Mar 3, 2010 | 10:01 AM
lars's Avatar
lars
The "out-of-the-box" tune on the MSD distributors is extremely conservative: The curve is long and slow. In order to get the distributor to perform properly you need to install the fat limit bushing in order to shorten the curve, and you need to install the softest springs in the kit to get the total advance in at 2500-2800 rpm. The short curve will allow you to get your initial timing up into the 16-18 range without exceeding 36 total.
Lars
Old Mar 3, 2010 | 08:18 PM
tbomb69's Avatar
tbomb69
6th Gear
Awesome, thanks everyone for the help.
Old Mar 4, 2010 | 09:15 AM
08vycpe's Avatar
08vycpe
As usual Lars is right on. Here are the curves for the MSD distributor. I like graph E with a blue bushing and one light silver and one light blue spring. The initial timing can then be set at about 13*. Graph F with 2 light silver springs works too but I didn't want the advance kicking in so close to idle.
To MSD 8572 Distributor Tuning Question
