Header Gasket Install
Old Mar 11, 2010 | 07:26 PM
willem wallace's Avatar
willem wallace
Default Header Gasket Install
Just got my Dougs Headers today, will probably install them this weekend. They come with their own gaskets, and recommend a thin coating of Ultra-Copper RTV on both sides of the gasket when assembling. I have GM aluminum "Fast Burn" heads. I am a little hesitant about putting all that RTV on the heads and header mating surfaces. Was thinking of just around each port for sealing, or perhaps another type of gasket. Can I get some feedback on this subject from your experience, this is my first hi-performance engine project.
Old Mar 11, 2010 | 08:20 PM
vettehardt's Avatar
vettehardt
Go to your parts store and get a set of copper (or aluminum) gaskets. They will never blow out and are reusable. I'v been using these for almost 10 years now with no problems. I have stock heads with hooker sidepipe headers. We used to go through 1 or 2 sets of gaskets a racing season until we put the copper ones on. I aslo don't seem to have to tighten the header bolts as much.
Old Mar 11, 2010 | 08:23 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I've never put any kind of RTV on header gaskets (been a mechanic since 1982) and don't know why it would be recommended.
Old Mar 11, 2010 | 08:40 PM
midyearvette's Avatar
midyearvette
i know what you mean but some manufacturers recommend it..go figure...
Old Mar 11, 2010 | 09:18 PM
Grumpy 427's Avatar
Grumpy 427
As long as both surfaces are flat and equal, the gasket along should be fine. Use a good thick header gasket , i have had good luck and no leaks with them.
Old Mar 12, 2010 | 08:25 AM
damoroso's Avatar
damoroso
Since you're changing headers and gaskets, you might consider using something like these locking header bolts... http://www.summitracing.com/parts/PHP-20004/?rtype=10 I've got them on my car and don't ever have to re-tighten them...
Old Mar 12, 2010 | 09:40 AM
TopGunn's Avatar
TopGunn
Use the original gaskets and put a coat of grease on both sides when you install them. They'll last for years.
To Header Gasket Install
