torque converter
Old Mar 13, 2010 | 02:40 PM
rbat's Avatar
rbat
Default torque converter
Need advice on a torque converter for a zz502 install is for smooth reliable street use
(th400 trans, 350 rear gears and street tires)
thanks
Old Mar 13, 2010 | 02:49 PM
10caipirinhas's Avatar
10caipirinhas
ATI 10"........
http://www.atiracing.com/products/tc/smtcprices.htm
Old Mar 13, 2010 | 06:17 PM
l88rocket's Avatar
l88rocket
12 - 11inch with a 2500 stall, and a good tranny cooler
Old Mar 13, 2010 | 06:57 PM
TimAT's Avatar
TimAT
A TH350 convertor will fit a TH400. Gives you a little higher stall, and way less cash than an aftermarket convertor. Problem is you never really know how much more stall you'll get. (it won't be less!)
Most 350 convertors have been rebuilt so many times by who knows how many people you never really know if they went in and replaced all the parts or just built one out of spare parts. And did they tweak all the vanes to spec or slap them together? But that's also pretty true of most aftermarket convertors too.
A cooler is never a bad idea- for anything that is going to get used hard. GM added them on trucks that were going to be towing.
Old Mar 13, 2010 | 07:08 PM
7T1vette's Avatar
7T1vette
If you are going to buy a converter, call the converter techs and let them spec one for you. Why would you get advice from folks who know nothing about your car? The techs will ask you all the right questions, take the data they need, and come back with the right converter for your engine/tranny and your driving habits. Just pick a good name brand [for God's sake, don't buy a converter at a local auto parts store ], and let them do the work.
Old Mar 14, 2010 | 02:55 PM
Bugman Jeff's Avatar
Bugman Jeff
I've had great results using Edge Racing Converters. Andre from Edge is super knowledgable and can set up a converter specifically for your needs.
Old Mar 14, 2010 | 06:34 PM
willem wallace's Avatar
willem wallace
Default Converter
Make sure you know what your existing converter bolt pattern is. Not all TH350 and TH400 converters are interchangeable. GM used two different bolt patterns, 10.75" and 11.50", so it is dependent on what flywheel you have.
Old Mar 14, 2010 | 08:43 PM
rbat's Avatar
rbat
Default help
this is true, but I like to be able to know a little before I call, and was wondering who to call. I know nothing and have no experience when it comes to TQ conv. This is always a good place for advice and a general direction, yourself included.... thanks for the help.
Old Mar 15, 2010 | 12:55 AM
jordan89's Avatar
jordan89
And make sure you add a good transmission oil cooler of you want the tranny to last.
Old Mar 15, 2010 | 01:45 AM
rbat's Avatar
rbat
Default trans cooler
I have a new 3 core alum rad with two 12" 1365 cfm spal electric fans.
Will I need a seperate trans cooler with this set up, if so which do you recommend?
btw, I live in hot south florida
Old Mar 18, 2010 | 11:45 AM
rbat's Avatar
rbat
Default ttt
ttt
Old Mar 18, 2010 | 03:09 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Originally Posted by Bugman Jeff
I've had great results using Edge Racing Converters. Andre from Edge is super knowledgeable and can set up a converter specifically for your needs.
I think Edge converters may be the best bang for the buck on the market. I have used them for two racing seasons and they have been flawless. 1.08 60' times, over 1200 hp and it has been flawless....all for 650.00 bucks.
I told Andre I wanted to go through the traps at 7500 rpms at 180 mph. Data logger says finish line rpms are between 7496 and less than 7600. He hit it right on the head, first try.
His street converters are less money than his race versions like mine.
Old Mar 18, 2010 | 07:45 PM
rbat's Avatar
rbat
Default TCI Tech
I called TCI and he said to go with the Sat. Night Special, it is about 200rpm over stock
I will call B&M and Hughs tomorrow and see what they say
To torque converter
