Quadrajet
Old Mar 17, 2010 | 02:43 PM
SteveG75's Avatar
SteveG75
Originally Posted by Gun Laker
Ok, today I went out and worked with the timing. The vacuum line to vacuum advance was removed and plugged. My initial setting of
8 degrees was already set (factory specs). I double checked the idle setting with and without a rubber band on the weights, no change. At about 2800 RPM (any higher RPM's did not change the reading) the timing was 14 degrees more or at about 22. I turned the distributor until the reading was at 32 degrees (8 initial + 24). The can added on about 14 degrees. The engine seems to run ok, but now the initial setting is at 16-18 degrees at the slowest idle I can get. Ok now if the difference between idle and high RPM should be about 24 degrees difference, what do I need to do to correct the issue. It seems to me I may need lighter springs? I have a stock HEI distributor that has never been modified as far as I know. The manifold vacuum at idle at the higher initial setting of 18 was better. Maybe I am confused so I am looking for thoughts.
Sounds about right to me. I run about 16-18 degrees (mechanical) at idle as well. I run 36 degrees mechanical all in by 2500 rpm. I used lighter springs to bring the advance curve in faster. I also use manifold (vice ported vacuum) at idle to smooth out the idle.
The reason that GM retarded the timing to 8 BTDC at idle and used ported vacuum for vacuum advance was in order to pass emissions. How often is your engine at less than 2000 rpm when driving?
You are now tuning for performance.
Old Mar 27, 2010 | 10:09 PM
Gun Laker's Avatar
Gun Laker
Originally Posted by lars
Idle fuel is metered and restricted by the oriface in the Idle Fuel Restrictor Tubes. Power piston position has very little effect on idle quality if the carb is idling on the idle circuit. If the carb is set up so lean that it won't idle on the idle circuit, the raised power piston will cause an extreme rich condition through the main metering circuit if the carb is idling on the main circuit.
The 77 carbs tend to run very lean, both at idle and at WOT. You may need to enlarge the idle tube restrictions along with a significant jetting change. As a last resort, you can block the idle air bypass holes to force engine to pull more fuel through the idle and transition circuits.
Lars
Lars, what main jet and primary rods do you recommend? I set the primary rod height like you suggested in one of you papers via the adjusting screw and a dial caliper and that seems to make a big difference. I also rebuild the carb and found several tubes were blocked and one had fallen into the bowl. The primary rods had a fair amount of corrosion on them as well. My vacuum at idle is about 14 inches. Should I get a lighter spring? The stock jets are 77 and primary rods are 52. Spring is #7029529. What size of restriction tubes and where can a person buy those from?
