'71 Headlight oddity
Old Mar 11, 2002 | 12:37 PM
Monkeywrench's Avatar
Monkeywrench
Default '71 Headlight oddity
The aim shows that the holes where the bearing shaft goes through are supposed to be slotted out the top to allow you to remove the lights door without too mucg trouble. As you can see, mine are not. Think maybe this is not a '71 headlight bracket or did they change mid-year?
Old Mar 11, 2002 | 01:12 PM
lbell101's Avatar
lbell101
Default Re: '71 Headlight oddity (Monkeywrench)
Those holes are correct. They hold the hinge that the top cover pivots on. They are slightly slotted for adjustment. The ones that are slotted to the top are on the backside. Should be three holes spaced out along the back side with two of them slotted open to the end.
Old Mar 11, 2002 | 02:31 PM
72rdstr's Avatar
72rdstr
I disassembled mine yesterday ('72) and it is the same. I think they have a loose definition of "slotted". :yesnod:
To '71 Headlight oddity
