Cragar SS Wheels?
Old Mar 18, 2010 | 04:54 PM
ED69ray's Avatar
ED69ray
Originally Posted by Apocolips
would these fit without spacers
yes
15x8 with 245/60 rubber on all 4 corners and no spacers
Old Mar 18, 2010 | 09:31 PM
marz's Avatar
marz
Originally Posted by Priya
Cragar SS's look weird and disproportionate in sizes larger than 15"
Mine are 17" and look fabulous!
Old Mar 18, 2010 | 09:33 PM
marz's Avatar
marz
Does anyone have Cragar SS's mounted on a 1970 or equivalent? I love these wheels and would like to get them for my car, but I have been told that they will not fit because of clearance issues with the brake caliper.
I have an extra set just sitting here. Send me $5 for shipping and I will send them to you. They are no problem on the wheels and I have had them on two C3 Vettes.
Old Mar 19, 2010 | 12:23 AM
TheFinn's Avatar
TheFinn
Marz, could you post a bigger photo of your ride with those wheels, please?
Old Mar 19, 2010 | 07:42 AM
marz's Avatar
marz
Here is what it looked like. I have recently sold the bad boy, but it will give you an idea.
Old Mar 19, 2010 | 08:28 AM
TheFinn's Avatar
TheFinn
Thanks, mate. I think they look really nice in 17" size.
Old Mar 19, 2010 | 09:03 AM
Apocolips's Avatar
Apocolips
Extra set of Cragars?
Old Mar 19, 2010 | 10:55 PM
gdh's Avatar
gdh
I have 1/2" spacers on my 15 x 8 Cragars. I also have 255 on front and 275 on the rear with no issues.
Old Mar 20, 2010 | 06:39 PM
Priya's Avatar
Priya
I spoke to my husband and as I suspected spacers aren't street legal here and he said even if they were they cause issues with tire alignment and premature tire wear. I can't tell from Cragar's website, but does anyone know if they make a 15X8 Cragar SS with an offset that will fit a Corvette without spacers?
Old Mar 20, 2010 | 07:00 PM
Corvettetodd's Avatar
Corvettetodd
I just installed these on my 71 Coupe.. No spacers or modifications needed.. bolted right on...
http://www.summitracing.com/parts/SUM-141-5861C-19/
Old Mar 20, 2010 | 10:52 PM
Apocolips's Avatar
Apocolips
I saw your other post and really liked the look. I also decided against anything that required a spacer. This afternoon I ordered the same wheels from Summit. Can't wait to get them installed. Thanks!!!!
Old Mar 21, 2010 | 08:18 PM
vettme's Avatar
vettme
Why would these fit without spacers when Cragar of the same size and back spacing need them?
Old Mar 22, 2010 | 12:45 AM
  #33
TheFinn's Avatar
TheFinn
Originally Posted by Jclgodale3
Because the AR Torq Thrust II's have arched spokes
More room for calipers, me thinks.
Old Feb 6, 2011 | 10:57 AM
  #34
1974ta's Avatar
1974ta
I know this is an old post but thought I would chime in.
You can order cragar ss in special back spacing so no need for spacers. They are direct fit meaning no unilug!
I believe 15 x 8, 5 x 4.75: bolt pattern, and 4" back spacing is about perfect. Tire size is 215 70R 15 or 225 70R 15. There are rare occasions where 225s rub.
Summit Racing has them for about $169.00 each. They may even include shipping.
I have been looking for months and that is how I discovered that you can special order them.
Bill
Old Feb 6, 2011 | 11:46 AM
  #35
Priya's Avatar
Priya
That's great to know Bill. I want Cragar SS's on my Corvette but spacers are illegal here. Can you tell me what you need to specify to order the ones that fit ?
Old Feb 6, 2011 | 01:41 PM
  #36
1974ta's Avatar
1974ta
If you go to Summit the easiest way to get their is search custom size Cragar ss. The are also available at Vintage Wheel Works but are more expensive there.
There will be a form on line to complete prior to placing the order.
If yours is a 70 like mine the specs are as follows:
15x8 rims with 5x4.75" bolt pattern and 4" back spacing. The 4" back spacing is the same as 15x8 ralleys they came with from the factory.
The tire size closest to original where you can be assured of no rubbing is 215 70R 15. Most times a 225 70R 15 will fit but note that some have reported rubbing issues with 225s.
Just wish there were better tire choices in the correct size with RWL.
There are three that I know of with solid white letters which is what I will get.
BG T/As, Firestone Indy 500s, and Mickey Thompson S/Rs
Reviews lean towards Indy 500 but I am not sure I like the letter size. BFGs seem to have a sub par riding quality, I like the letter size of MTs but their are no reviews.
Good Luck and post pics if you get them.
Bill
Old Feb 6, 2011 | 03:10 PM
  #37
Priya's Avatar
Priya
Thanks again Bill, much appreciated.
To Cragar SS Wheels?
Old Feb 6, 2011 | 04:12 PM
  #38
cm2dinger's Avatar
cm2dinger
sorry to hijack but what is that color? i lovve it.
Old Feb 11, 2011 | 03:23 PM
  #39
Corvette World's Avatar
Corvette World
1st Gear
Bill
I just ran into this problem with a customer of mine and Cragar SS. It is not the back spacing that is the problem with the Cragars. I ordered him the same wheel that you are talking about above and the spokes hit the caliper. The wheel I ordered was an Aluminum SS with the gray spokes - Cragar # 610G583445.
Jared - Corvette World
Old Feb 12, 2011 | 01:08 AM
  #40
rod7515's Avatar
rod7515
Default cragar ss
I have a 72 and I searched for a long time to find a set of ss wheels that would fit without spacers. I had no luck. My heart was set on the cragar ss rims so I went with the 1/2" spacer on all 4 wheels. I have 225/70 15 on frt with 7" rim and 255/60r15 on rear with 8" rim. Tires are just about at the edge of the rear fender well and frt fender well. Rear tires are close on inside but since Im not home I cant remember if its the shock mount or something else back there. I think theres about 1/2" clearance. The wheels and tires (BFG) look awesome but its becomes a personal preference. Also I am not sure why the spacers would make a difference for frt end alignment. I was always told they set caster / camber and toe from the hubs? I havent had the car out on the road yet to see how the spacers hold up. I'm not in love with using them but like I said my heart was set on Cragar ss wheels!
Rodney
