Cragar SS Wheels?
Old Feb 12, 2011 | 08:22 AM
  #41
1974ta's Avatar
1974ta
I can only think that the 4" bs that hit the calipers was because of non stock calipers. I do know that aftermarket calipers can pose a problem with 4" bs.
Keep in mind you can order 3.75", 3.5" back spacing as well. Spacers are just not a good idea.
I canceled my order because now I need to do some more research.
4" back spacing should be perfect with a stock set up, but I am a little nervous since they are custom order.
The spokes on classic ss are flat in the back. Not sure why 4" will not work. I am hoping to find an old beat up unilug with 4-1/4 back spacing to test. If 4-1/4" works then 4" will for sure. If 4-1/4" does not work I will test with spacers until it works and that is the bs I need.
Bill
Old Feb 12, 2011 | 10:13 AM
  #42
Priya's Avatar
Priya
Originally Posted by rod7515
I was always told they set caster / camber and toe from the hubs?
Rodney
No, its set from the outer edge of the rim. A measuring device is clamped to the outer edge of the rim on each wheel.
Old Feb 12, 2011 | 08:54 PM
  #43
tarheeljww's Avatar
tarheeljww
I have a set of the cragar 40th aniv SS in 16 x 8 and they fit fine.....
BTW, as I picked up a set of Foose 17s the Cragars are for sale with a set of Dunlaps included.......mounted, but never seen the road.
Old Feb 13, 2011 | 10:16 AM
  #44
Tele_Man's Avatar
Tele_Man
I've been running Cragar SS on my '69 since 2003 with the 1/2" spacers. It's a close shave to the brake calipers, but I've never had a problem.
The AR wheels are nice, but I think the Cragar wheels are more correct for the era of the car in the later sixties.
Old Feb 13, 2011 | 10:37 AM
  #45
boomhwr's Avatar
boomhwr
5th Gear
got pics??? legends are awsome!!
Old Feb 13, 2011 | 11:04 AM
  #46
Tele_Man's Avatar
Tele_Man
Old Feb 14, 2011 | 04:21 AM
  #47
vettehardt's Avatar
vettehardt
Bill
Backspacing really has nothing to do with whether the wheel will hit the caliper or not. It is how the backside of the spokes are designed that matters. If the spokes come straight out from the hub surface, they will most likely hit the caliper. That is where you will need the spacer to push the wheel out. If the back side of the spokes arch out towards the front side, they will most likely clear. There are people on this forum that are running a 5.5" back space wheel (on the rear) with no problems of hitting the caliper. The drag racers who are running skinnies on the front most likely have a 2-2.5" back space and have no problems. Stock 15X8" aluminum wheels were 4" back space and didn't have problems.
Back spacing is the distance from the mounting surface to the back edge of the rim. The backspacing will effect how much clearance there is between the rim/tire and the frame, steering parts, trailing arm, and suspension parts.
A spacer shouldn't effect your alignment unless the two surfaces of the spacer are not parallel.
Old Feb 15, 2011 | 02:53 PM
  #48
my 76 ray's Avatar
my 76 ray
What he said.
Old Feb 15, 2011 | 03:50 PM
  #49
arcticcatmatt's Avatar
arcticcatmatt
SS's on my 71 with spacers
Old Jul 8, 2017 | 04:23 PM
  #50
braymond's Avatar
braymond
5th Gear
Default cragar s/s wheels
does cragar make an s/s wheel for a 2005 corvette coupe? rear wheels are 19 inch and front wheels are 18 inch
Old Jul 9, 2017 | 08:43 AM
  #51
540 vette's Avatar
540 vette
Go to Jegs and look. If they don't have them they aren't made.
Old Jan 14, 2026 | 01:17 AM
  #52
Shane Gates's Avatar
Shane Gates
1st Gear
Default What part numbers are correct?
Does anyone know how to confirm the part numbers for one that does work on a 78?
