Originally Posted by 69427
I was always under the understanding that dwell is cam/distributor degrees, not crankshaft degrees. Given that the points dwell is cam degrees, not crank degrees, increasing the points dwell one degree will change the crank dwell angle two degrees.
You're absolutely correct. Dwell is the number of degrees of camshaft travel that the points remain closed. I have edited and corrected the previous posts to coincide with this factual correction.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by lars
You're absolutely correct. Each one degree change in dwell will change timing 2 degrees because dwell is the number of degrees of camshaft travel that the points remain closed. I have edited and corrected the numbers in my previous posts to coincide with this factual correction.
Not trying to beat a dead horse (), but the timing won't change two degrees. If you increase the dwell one (distributor/cam) degree, the dwell will turn on one half degree sooner, and end one half degree later. This one half (cam) degree delay (in points opening), multiplied by two, gives a one degree incremental retard to the spark timing.
All I know is that when I checked my dwell the other night it was at 34 degrees and timing was at 6 degrees.
I reset dwell to 32 degrees and my timing went to 8 degrees , which I then backed off to 4-5 degrees trying to eliminate a slight (lean ?) surge around 45-50 mph.
I just acquired about a dozen sets of Motorcraft GM Hecho in Mexico points.
I had the opportunity to go through a case (at least 100 sets) of FORD Motorcraft points and selected about 10 sets that had no up and down play in the breaker arm and had perfect contact alignment.
These are ventilated points and have 28 oz tension.
Anybody have any experience with these - when I get brave I will try running a set and see how they hold up.
