Sealing threads
Old Mar 24, 2010 | 07:52 AM
ssenay72's Avatar
ssenay72
Default Sealing threads
Ok lets talk sealing threads on various fittings and what to use...
Fuel lines??
Transmission cooler lines??
Water fittings?? (intake,water pump etc.)
Plumbers tape on any? Liquid sealer??
Old Mar 24, 2010 | 08:25 AM
ZZ71S's Avatar
ZZ71S
Head bolts would interest me
Old Mar 24, 2010 | 08:32 AM
schmegeggie's Avatar
schmegeggie
Fuel lines??
Fuel lines shouldn't need sealant. Most if not all on these cars are "inverted flare" fittings and don't seal on the threads, they seal on the inner seat of the flare. The threads simply help drive the seat onto the sealing surface. You could use teflon tape, because that's just a thread lubricant, not a sealant, but I wouldn't. Fuel will eat thread sealant anyway, or worse go into the carb.
Transmission cooler lines are probably the same type fittings, although I have a 4 speed, so I'm not sure.
Your water fittings can be sealed with Loctite PST #567. It works on both carbon and stainless steel and has a 400 degree temp. rating. Make sure the fittings are clean,use Primer N #7649 or some type of cleaner.
Good Luck!
Old Mar 24, 2010 | 08:39 AM
hugie82's Avatar
hugie82
I have used plumbers gasline sealer on some lines beacause if a piece of teflon tape breaks off it can cause problems down the line.
Old Mar 24, 2010 | 10:07 AM
7T1vette's Avatar
7T1vette
Fuel lines: fuel lines should have sefl-sealing type fittings that are in good condition. If a fuel line fitting doesn't seal, you need to change it.
Tranny lines: you can use Teflon tape on pipe thread connections [if you want], but sealant made for hydraulic connections would be better.
Water lines: Teflon tape or plumber's sealant.
Note: Teflon tape is 'slippery'. Unless a fitting does not have a tendency [or the ability] to back out of the mating part, it may not be the best item to use. Other sealants tend to help hold the pieces together; teflon 'assists' them in working apart.
Old Mar 24, 2010 | 10:37 AM
682XLR8's Avatar
682XLR8
I use Teflon sealant(not tape) on head bolts and screw-in rocker studs, have not had a problem yet. Comes in a tube and is sold by Permatex
Old Mar 24, 2010 | 08:16 PM
ssenay72's Avatar
ssenay72
Well take for instance an aftermarket fuel pump. The two fittings on the pump itself just screw right in, theres no flare on those. Should i seal those with something?
Old Mar 24, 2010 | 08:51 PM
7T1vette's Avatar
7T1vette
If you use teflon tape on fine pipe threads [in a fuel system], just make sure to leave the end two threads free of teflon so you can't get any loose bits of tape into the fuel system (plugs up filter or can stick needle valve open).
To Sealing threads
