Tstat temp question:
Old Mar 29, 2010 | 09:56 AM
Kevins77's Avatar
Kevins77
Default Tstat temp question:
What temp t-stat do you guys reccomend? Looks like mine is sticking open as of saturday. Kind of odd to look down and see the motor hovering around 150* after a couple hours of driving around.. lol.
The motor is a 383 with aluminium heads and an electric fan setup. The fan is wired always on (done by whoever had the car before I did) to a 15amp fuse.
Old Mar 29, 2010 | 09:58 AM
midyearvette's Avatar
midyearvette
your ideal running temp is 180 degrees, others may dis agree.....jmo....
Old Mar 29, 2010 | 10:09 AM
DaJesterMan's Avatar
DaJesterMan
you may also want to check the accuracy of your temp gauge in some boiling water.
Old Mar 29, 2010 | 10:11 AM
bashcraft's Avatar
bashcraft
180*.
What's in it now?
Old Mar 29, 2010 | 10:36 AM
Kevins77's Avatar
Kevins77
I have a 185 t-stat in it at the moment, which was working fine. It would normally operate between 180*-200*. Noticed yesterday it was at about 190 for most the drive, then it just dropped to 150*. It never got back up to 185 for the rest of the day, even when idling for longer periods of time.
Usually when that happens, the Tstat gets stuck open. I'll test the temp gauge in some hot water tonight before I replace the themostat just to make sure though.
Old Mar 29, 2010 | 04:46 PM
71coupe454's Avatar
71coupe454
The fans should only come on when needed, not run all the time.
Old Mar 29, 2010 | 05:03 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
A 180 F thromostat should keep the oil above the boiling point of water, which is 212 F.
Old Mar 29, 2010 | 07:16 PM
jordan89's Avatar
jordan89
You should also go with a 180*.
Old Mar 29, 2010 | 10:06 PM
Kevins77's Avatar
Kevins77
Thanks guys,
I put in a new 185* and tried it out. Looks like its operating back where it should be. Always nice when you can get away with a $4 fix
To Tstat temp question:
