jet size
Old Mar 29, 2010 | 08:58 PM
painterman52's Avatar
painterman52
Default jet size
I`m putting a 650 holley double pumper on a 383 with a cam that is 230/236 @.50. It was on a 350 with a 227/230 cam. How many jet sizes should I go up?
Old Mar 29, 2010 | 09:08 PM
marz's Avatar
marz
First off you need to trade that 650 for a 750 for added power for that 383. But, if you want to keep it you need to get a jet kit and go up two sizes at a time until you get it to where it is not running rich or lean. That motor will want some fuel. But, the 750 will give you more air and that motor will want more air and fuel. Let us know how you come out. Check the air/fuel mixture as you adjust.
Good luck.
Old Mar 29, 2010 | 11:08 PM
lars's Avatar
lars
A carb doesn't know what size engine it's on. Set the carb up to its stock specs and tune it from there based on the observed needs of the engine.
Contrary to popular belief, a small carb on a big engine receives a stronger metering signal and will run rich. You don't randomly jet a carb up because a big engine "needs more fuel." Start with the stock baseline and tune from there, otherwise you'll be chasing your tail.
Lars
To jet size
