TACH Problems
Old Apr 6, 2010 | 09:46 AM
warrior2291's Avatar
warrior2291
Default TACH Problems
Hi i have a 1980 Corvette L-82.
The tach stop working last night on the way home from work. With the ignition off it stays at the 3500 rpm mark. When driving it stays at the 4000 rpm mark. Any ideas where to look first? should I replace the cable? it never drops back to zero nor is the any movement from the needle.
Old Apr 6, 2010 | 09:54 AM
MelWff's Avatar
MelWff
You dont have a cable, it's electric. Others will have to chime in to tell you what to look for
Old Apr 6, 2010 | 10:21 AM
warrior2291
Default Tach
Originally Posted by MelWff
You don't have a cable, it's electric. Others will have to chime in to tell you what to look for
Thank you very much that's a great start for me....
Old Apr 6, 2010 | 12:41 PM
marz's Avatar
marz
Probably need it re-worked. I know most use a circuit board that always fails. Not sure about yours, but I would bet that is what has happened. Look at one of the Corvette parts sites and see if they have tach re-build service for your year model.
Old Apr 6, 2010 | 12:52 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
On mine the wire that goes to a noise supressor on the intake broke , I took the supressor out and wired them together and the tack started to work , cream coloured wire and a small bracket on the passenger side beside the distributor! or like above the tach printed circuit! Ron
Old Apr 6, 2010 | 03:25 PM
thegazman's Avatar
thegazman
Default thegazman
If you continue to have problems check with Willcox here on the forum. They are real good with tach's and stock most needed parts.
Old Apr 6, 2010 | 05:12 PM
warrior2291
Default Tach
Yep I was reading my manual and you are right I have already purchased all the bulbs, and circuit board.
I was just waiting to install it all, it looks like my weekend project for this weekend. thanks for the help!!!
Old Apr 6, 2010 | 05:13 PM
warrior2291
Default Tach
yes I have been looking at them and i think if the board does not fix it i will go with them to fix mine and up grade it.
Old Apr 6, 2010 | 05:36 PM
7T1vette's Avatar
7T1vette
The areas of possible cause are: 1) bad signal wiring from tach to circuit board (behind gauge cluster); 2) bad tach signal filter (the little can mounted to the intake manifold in that tach signal line; 3) bad circuit board [see #1]; bad tachometer. The likelihood of those causes can be prioritized as #3, #1, #4, & #2 [IMO] because of the symptoms you described. But, since the circuit board and tach are the most difficult to check out/repair/replace, verify integrity of #1 & #2 first. If you pull the circuit board out, check it over very closely; the problem may simply be a broken conductor foil on the board which prevents the tach signal from getting to the tach. If so, a simple solder job can fix it and save a bunch of $$$$.
Old Apr 8, 2010 | 01:08 PM
warrior2291
Default Tach
Hi thank you for the very detailed list this will help me a lot. Since I have just about restored this car. I am currently working on the last few details. The Tach started this week not working correctly.
It stays at 3500 rpm when I am driving it or not (shut down) and will go to 4000 rpm and stay there and then drop no lower than 3500 rpm at slower speeds usually less than 45 mph.
I have replaced the circuit board for the center bezel with gauges and all the light bulbs as well as the lens. So I was planning on removing the tach and speed o and replace the lens there too along with the bulbs and circuit board I already bought. that way the dash will be completely re done with everything new.......thanks again!
Old Apr 10, 2010 | 04:13 AM
hunt4cleanair's Avatar
hunt4cleanair
Most often its the tach board...read this recently published article on tach boards in CE...
Tach Repair
Old Apr 19, 2010 | 04:54 PM
warrior2291
Default Tach repaired
Tach Repair
Good news I found the problem. I had to replace the Tach board with a new one. Awhile I was at it I replaced all the bulbs and the Speed o and tach circuit board as well as the tach board it self......
It works too!!!!
To TACH Problems
