Remote power door locks-possible??
Old Apr 6, 2010 | 11:23 PM
tom benjamin's Avatar
tom benjamin
Default Remote power door locks-possible??
Is it possible to make my power door locks on my 78 to operate with a remote key pad like the new cars ?? If so do they make a kit for this or use one from a new car, how do the new ones work? is the siginal sent to a receiver on the accuator? input please, thanks Tom.
Old Apr 7, 2010 | 01:00 AM
enkeivette's Avatar
enkeivette
Easy, just buy an alarm with a key fob. If you don't have power door locks you can bolt universal actuators inside the door. I'll be doing this during the summer with a Viper alarm.
Old Apr 7, 2010 | 01:21 AM
speedreed8's Avatar
speedreed8
i installed a remote door lock kit, from jc whitney, a couple of years ago in our 79.
remote box is in the drivers kick panel, but had to run the wires all the way to the drivers side master lock switch in the door panel. to get it to work correctly.
Old Apr 7, 2010 | 09:50 AM
7T1vette's Avatar
7T1vette
The '82 C3 had them, I believe. They should adapt to your door hardware without too much problem. You will need to add some wiring.
Old Apr 7, 2010 | 10:18 AM
zwede's Avatar
zwede
If you don't want/need an alarm you can get just the keyless entry that hooks into your factory power locks:
http://www.parts-express.com/pe/show...number=330-145
http://www.parts-express.com/pe/show...number=330-535
Old Apr 7, 2010 | 10:38 AM
78IndyPace's Avatar
78IndyPace
Here's a link to a thread on this forum with more info:
http://forums.corvetteforum.com/c3-t...e-step-in.html
Hope this helps.
Jerry
Old Apr 7, 2010 | 12:51 PM
toddalin's Avatar
toddalin
Cheapest way to go:
For those who need the door actuators, $5.50 is hard to beat.
http://www.allelectronics.com/make-a...UATOR/-/1.html
And of course, you need the transmitter and receiver. For 6 amps worth of control:
http://www.allelectronics.com/make-a...6-AMP/-/1.html
And for 15 amps of control:
http://www.allelectronics.com/make-a...5-AMP/-/1.html
To Remote power door locks-possible??
