engine wiring harness
Old Apr 6, 2010 | 11:53 PM
kwikcc's Avatar
kwikcc
Default engine wiring harness
Just replace engine wiring harness 73 small block no air automatic. Everything went well until I hit the starter. Replace the red purple and black ground fine.. the starter did not have the small yellow wire attached and the car has been starting fine..confused on attaching the yellow wire to the solenoid or leave it off as it was...any thoughts.
Old Apr 7, 2010 | 08:48 AM
Duke94's Avatar
Duke94
The yellow wire sould go to the 'R' terminal on the solenoid. Purple goes to the 'S' terminal.
Gary
Old Apr 7, 2010 | 09:43 AM
7T1vette's Avatar
7T1vette
The yellow wire connects to "S" terminal...which stands for 'start'; the "R" terminal stands for 'run'. The other end of the yellow wire goes to the + terminal on the coil together with the resistance wire coming from the fuse panel. The "S" terminal is only powered during start-up and has a full 12 volts on it. That is what is intended to feed the coil when you start the car. Once you have released the key into the 'run' mode, the power for the coil comes from the resistance line which supplies a lower voltage and reduces load on the coil {regardless of what others try to tell you}. Right now, you are only feeding the coil with the resistance line. That is working now, but in cold weather or other stressed condition, your engine might have trouble firing without a full 12 volts to the coil. Just attach that line to the "S" terminal on the starter solenoid.
Old Apr 7, 2010 | 10:52 AM
jim2527's Avatar
jim2527
Old Apr 7, 2010 | 11:49 AM
Duke94's Avatar
Duke94
That's odd, the Doc Rebuild wiring diagram I have shows the yellow to the "R" terminal. Is it wrong or is 71' different than 73'?
Gary
Old Apr 9, 2010 | 11:54 PM
kwikcc's Avatar
kwikcc
thanks for all the replies. what i am trying to figure out is that since i have had the car it has been starting fine with the yellow wire disconnected. now that i've replaced the engine wiring harness I am wondering if i should attach the new yellow wire or leave it off as it was. could there have been some reason the previous bubba disconnected it. this bubba does not want to make it worse.
Old Apr 10, 2010 | 01:51 AM
Peterbuilt's Avatar
Peterbuilt
Default Yes! Hook up the yellow wire.
The above instructions are 100% correct.
Old Apr 22, 2010 | 05:14 PM
kwikcc's Avatar
kwikcc
thanks for the diagrams and the support. all done car starts fine every thing works I hopefully am no longer an electrical bubba. Thanks to all for the help.
To engine wiring harness
