Engine HP question
Old Apr 8, 2010 | 03:59 PM
79blue's Avatar
79blue
Default Engine HP question
Years ago I blew the bottom on my 79 L-82, I purchased a short block from Jaspers and re-installed the original 2.02/1.60 heads, intake, carb and manifold. The blown original motor was .30 over and was no turtle. The new engine just is not as strong even with the larger bore. I'm guessing it's the cam that Jaspers installed. I would like to pep up the hp on a budget and retain the stock appearance.
This is what I know about the short block I have:
350 4 bolt
.40 over
Flat piston
500 +-miles
Unknown cam
Runs great w/no smoke
I would like to:
Reinstall the original L-82 cam
New heads or rework exsisting
re-use manifold and carb
Add 60's style 2-1/2" manifolds w/matching exhaust
My questions are:
1)Is the L-82 cam worth reinstalling?
2)Can I do any tricks with gaskets/porting with these smog heads?
3)What are a good set of heads (besides AFR $$) with accessory holes to add with that cam?
The AFRs and Comp Cam are what I like but, I'm also budgeting for the 200r4 swap.
Thanks in advance.
Old Apr 8, 2010 | 10:08 PM
cam cooper's Avatar
cam cooper
dont reuse old cam not worth taking a chance with it for the price of a new one go to comps web site and u can download their cam program for free its easy to use and fun to play with. afr heads are good ones and i have had real good luck with rhs cast heads in our pulling truck big blocks(800+ hsp)
Old Apr 9, 2010 | 09:42 AM
Ganey's Avatar
Ganey
Since you were happy w/ the L-82 cam you could get a new one. To use the old one the lifters should go back on the same lobes & check cam for wear.
Old Apr 9, 2010 | 11:23 AM
7T1vette's Avatar
7T1vette
If you change the heads, select the cam which will best match with the new heads. Don't go the L82 cam route and just add different heads. If you decide to keep the existing heads, then getting a new L82 [grind] cam would work.
Old Apr 9, 2010 | 12:05 PM
79blue's Avatar
79blue
Thanks, I'm going to the Auto Fair this weekend in Charlotte and will be looking around for some good heads etc..If I find something. I'm sure I'll post it, for some thoughts.
Old Apr 10, 2010 | 11:55 AM
1980 blue L48's Avatar
1980 blue L48
I did not know the late 70s L82 engines had 2.02/ 1.60 large valve heads. Bump
Old Apr 10, 2010 | 07:16 PM
cam cooper's Avatar
cam cooper
they did but they were open chamber smog heads better than most but still junk
Old Apr 10, 2010 | 10:59 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Your pistons are likely a little lower in the block than stock due to *rebuilder* type pistons. That will kill some compression. If your heads have 76cc you're not even at 9.0 with the flat tops....you're down in the 8.7 or so range on compression.
If you change heads I'd go for some 64cc chambers. That will get you up in high 9's...close to 10.0 compression and use some thin head gaskets. FelPro makes a .015" one that works with aluminum heads.
Once you have heads and compression figured out...then you can select cam. Having better heads and compression will really allow a good cam to work.
If you decide to stay with current setup and you don't pull heads (that .015" gasket would even help the iron heads!), then I'd look for a relatively short duration cam with a tighter LSA to help wake up that low compression.
If you can do the port work on stock heads...then go for it. But no way would I spend the $$$ to pay someone to mess with them. Not worth it. It's cheaper to just buy something better.
What trans and gears do you have?
JIM
Old Apr 11, 2010 | 04:35 AM
Rockn-Roll's Avatar
Rockn-Roll
Don't use the old cam...get a new or reground cam. Cam bearings are just aluminum sleeves and both the bearings and cam get severe wear from even light use. If it's just had 500 miles on the cam bearings then I don't think you need to change them, but definitely don't put a cam in there that has more than 15,000 miles on it.
I believe the 268H from Comp Cams is identical to the original L82.
Old Apr 11, 2010 | 01:55 PM
79blue's Avatar
79blue
Thanks for the advice. My son didn't have the patients to let me look at the Auto Fair, so I didn't see much as far as parts. Jim, I have a 350 turbo for a tranny and 3;55 rear gears. For the money, I like the idea of a shorter duration cam, tighter LSA and new gaskets. Just to see if it helps, new heads would be ideal but, I’m trying to avoid a couple of extra paper weights. "Rock n Roll" mentioned the 268H from Comp would that be a good consideration? Before I "put the buggy infront of the horse" Should I find out the compression first?
Old Apr 11, 2010 | 05:27 PM
79blue's Avatar
79blue
I checked two cylinders and they both said 70# . What does that tell me? I hate to sound engine stupid. Thanks
Old Apr 11, 2010 | 05:41 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Is that the cranking pressure? If so that's a tired ol motor
Old Apr 11, 2010 | 11:52 PM
427Hotrod's Avatar
427Hotrod
Yes...if it's 70 psi of a cranking compression....we now know why it has little power. Something ain't right. Go ahead and check all of them to see if there are any burnt valves or leaking head gaskets.
The 268H is a decent cam but it's not a copy of the L-82. It's a single pattern cam with assymetrical lobes. It's a good solid design that runs well in mild motors. But we need to figure out the compression issue first.
JIM
Old Apr 12, 2010 | 02:05 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
That tells you you have major problems. My stock L48 with 110,000 miles had a solid #140 across the board.
Old Apr 12, 2010 | 08:54 AM
79blue's Avatar
79blue
I borrowed a neighbor’s gauge; the threads seem long so I didn’t want to tighten the treads too far in the cylinder. So it's either the tool or the user, I will get another gauge with a shorter thread and check again. Thanks for the replies
Old Apr 12, 2010 | 10:57 AM
79blue's Avatar
79blue
Prevuios gauge was bad, Bought a new one from NAPA. I have 145-150#. 6 out of the 8. Assuming checking each plug one by one is o.k. Or should I remove all the plugs then check?
Old Apr 12, 2010 | 03:13 PM
Priya's Avatar
Priya
You should remove all the sparkplugs prior to doing any compression testing.
To Engine HP question
Old Apr 12, 2010 | 03:31 PM
midyearvette's Avatar
midyearvette
also, wire the throttle WIDE open and the choke open too....
Old Apr 12, 2010 | 03:33 PM
Priya's Avatar
Priya
I forgot about that critically important part - its been probably 20 years since I did a compression test.
Old Apr 12, 2010 | 07:44 PM
79blue's Avatar
79blue
Thanks, I'll start from the beginning. All plugs out, Throttle/choke wide open. I believe I'm off the HP question, trend should have been how to check compression., I'll start a new trend when I get a chance to start over. (kids,sports=busy week)Thanks again.
