4 Speed Automatic info Needed
You can go a number of ways to install an overdrive/lockup transmission in your car. Buying one ready-to-install is one way. You can buy a used unit and install it...hoping for the best. You can buy a used unit and rebuild it yourself. Or, my favorite, buy a used unit and take it to a reputable/quality transmission repair place and have them do a good rebuild on it.
the above posts show nothing about the transmissions in question....
I have called you on that mis match of knowledge a few times, but it's time to toss the glove....
there is a HUGE generational distinction in the electronic controls of transmissions, the lock up of earlier converters are about the SAME for the 700 r4 and the 200 4r even the 4 pin plugs are the same, the lockup is typically controlled by a 4th gear pressure switch in the hydraulic brain internal to the tranny, sometimes with a series temp switch to allow that to happen when it it warm enough...
which is strange to ME, but that is another topic...
I have installed both a 700 and now a 200 in my '72 shark...true I have EFI but really now, I CAN flip a switch between computer at 50 mph or to lock either of them at 2nd gear and stay locked ...I did it for the fun factor, normal driving these daze is left in the computer controlled position...but at any rate that 4th gear lockup switch is supposed to be active....
the second generation was with NEITHER of these trannies, and they are the ones that share GUTS only, but the case/brainplates are totally different...and require the computers to run them costing about a GRAND or so in bux....outside the tranny itself....
the 700 r4 and the 4L60 are nearly identical...except for <87 to >87 then you get into the brain plates and aux valve bodies....
but the 4L60e and the 4ZL80e are totally different animals and will take a expensive act of God and CONgress to install in a Shark Vette...
CASE CLOSED.....
I have a complete kit with the 4spd shifter conversion new crossmember and all for $3695 less the forum discount. A good customer of mine has already put several in with out my kit.
To the OP you can buy a used 4l60e or 700r4 they will fit into your car.
There are several company including us that make a crossmember. The 4l60e will be more money because you need a controller. However it shifts better and is more efficient. No messing around with valve bodies or tv cables. Set it once and roll on.
This is a very easy conversion, I did mine in an 81 for about $1100 including a complete rebuilt trans,crossmember and drive shaft.
bowtieoverdrives.com is a great place to look at for what you'll need to make the conversion. They sell everything you'll need even if you buy a salvage yard trans.
Good luck
Bill
I think a non Vette 700R4 can be modified to do the same by changing some internal part like this.
but without a TG kit in there, I would not bet on ANY tranny to last worth a damn.....
