swapping points for electronic ignition
Old Apr 12, 2010 | 09:38 PM
joepcad's Avatar
joepcad
Default swapping points for electronic ignition
any hints? location of 1st cylinder is different on the points to HEI. we can get it to run, but won't idle. eliminated vacuum, carburator.
Old Apr 12, 2010 | 09:43 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
????? You can put #1 wherever you wish, on either distributor.
We need a bit more information here.
Old Apr 12, 2010 | 10:03 PM
joepcad's Avatar
joepcad
got timing at 12 degrees BTDC when rev motor timing mark goes to 0. Is this correct or not?
Old Apr 12, 2010 | 10:07 PM
joepcad's Avatar
joepcad
it has an aftermarket cam, unknown size, Edelbrock I think 1405 carburator, timing seems to run 12 BTDC and will not idle for long, it will not run at all at 8 BTDC which is the recommended.
Old Apr 13, 2010 | 06:23 AM
cam cooper's Avatar
cam cooper
how did u install cam?straight up,addv.,retard?
Old Apr 13, 2010 | 08:15 AM
jnb5101's Avatar
jnb5101
i've changed two cars to hei. both times (even though i took care ) i had to move all the wires over one position. could be i just wasn't careful enough. that being said, set the distributor (with vacuum off) to 36 degrees advance at 3000 rpm and forget about idle setting. see what that does.
Old Apr 13, 2010 | 09:42 AM
Mike Ward's Avatar
Mike Ward
You're probably not on the #1 plug wire with your timing gun.
Old Apr 13, 2010 | 09:46 AM
Golden's Avatar
Golden
I also wondered this.
Old Apr 13, 2010 | 12:04 PM
7T1vette's Avatar
7T1vette
There is NO need to swap your plug wire positions when changing to HEI. You can do so, if you shift all of the plug wires the same direction on the cap...but there is no need to do so.
As mentioned above, all that is necessary is that the rotor contact be aligned with the cap contact which sends the signal out to the correct plug wire/plug. If your engine is rotated to be at TDC on cylinder #1, then the rotor contact had better be adjacent to the #1 contact in the distributor cap...and the wire in that location on the cap must be going to the #1 plug.
Old Apr 14, 2010 | 08:09 AM
jnb5101's Avatar
jnb5101
if the number 3, 5 or 7 wire was used to trigger the timing light, the timing would be at least 45 degrees off. would the engine even start?
Old Apr 14, 2010 | 01:10 PM
7T1vette's Avatar
7T1vette
The TDC mark on the damper is only for cylinder #1. Timing for the other cylinders is in various locations [at 45 degree increments] on the damper and in sequence with the ignition firing order.
Old Apr 14, 2010 | 01:15 PM
71_S-Ray's Avatar
71_S-Ray
If you are going from 12* to 0*, then you must be set at 12 ATDC, not BTDC because revving the engine increases timing. This would easily explain why you won't idle. Otherwise, you may be off 180* on your distributor.
Old Apr 14, 2010 | 01:47 PM
lars's Avatar
lars
If you eliminated the vacuum advance your idle quality is going the suffer and idle speed will be much lower.
Forget initial timing and set your total timing to 36. Then hook your vacuum advance up.
Lars
Old Apr 14, 2010 | 02:22 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
You got the pickup wires reversed...
Swap the wires, then re-time and watch the timing mark on the damper as you raise the rpm - the timing should advance smoothly without jumping back to zero. Remember that the ignition fires when the 8 starred points of the reluctor meet those of the magnetic pickup.
Old Apr 15, 2010 | 10:08 AM
larrywalk's Avatar
larrywalk
I found my earlier explanation of why the spark can retard when the engine rpm is increased, but didn't want to retype the whole thing again...
See Post #28:
http://forums.corvetteforum.com/c3-t...-timing-2.html
Cheers!
Old Apr 15, 2010 | 11:39 AM
jnb5101's Avatar
jnb5101
larry
i follow your explaination, but what do you mean "switch the pick-up wire"? are you referring to the trigger pick-up? or internal wires on the unit? and if so, what do you switch it to?
Old Apr 15, 2010 | 12:18 PM
larrywalk's Avatar
larrywalk
The two pickup wires from the magnetic sensor, if switched, will cause the problem I described. Let us know what works.
Cheers
Old Apr 15, 2010 | 01:12 PM
69427's Avatar
69427
Cheers
Excellent point, Larry!
OP: I don't understand how it's possible to get the two wires swapped around in an HEI distributor. Is this an actual HEI, or some aftermarket setup claiming to be an HEI?
To swapping points for electronic ignition
