Need to replace the #4 body mount brackets on my 1971 convertible, both upper and lower. Where is the best source for quality replacements of these parts? Any info is appreciated.
I got my upper no#4 body mount support from Paragon.
But, Ecklers,Zip,Corvette America,and others all have threm.
Lowers as well.
Steve
If they are not too bad, you can try repairing them.
We have never had any issues with ours and we sell a lot of them.:
From: Las Vegas - Just stop perpetuating myths please.
#4 mounts see the worst enviroment due to location behind rear wheels. I replaced my rubber mounts only to have them split up after recommended torque. Replaced them secound time and used lower torque. I was lucky and only had minor corrosion on body side of one bracket but i can see where it could be worse for others.
My fix was just POR15 - just wire brush clean and apply POR15. If i were to replace all rubber mounts again i would install poly mounts on the end mounts (#1 & #4) and use the rubber mounts on the inside mounts (#2 & #3). More rigid and durable at the ends and still has some squish below the people compartment.
Good luck on bracket replacement as i have read u need to find the right adhesive and pop rivets for the body brackets. A guy named NH Vette did this but hasn't posted here for a long time now.
