Power steering problem.
Old Apr 19, 2010 | 10:07 AM
Nitro DarkSide's Avatar
Nitro DarkSide
Default Power steering problem.
I have a 73 with a problem on the power steering. The steering is hard, but just when i turn right. It seems normal when the car is cold.
The previous owner did tell me about the problem and also about a small leak.
I took some pictures:
How can i solve this problem?
Thanks.
Old Apr 19, 2010 | 10:27 AM
slapshot 496's Avatar
slapshot 496
I had the same problem as you describe,i got the front end off the ground and turned the wheel lock to lock several times until the wheel turned evenly/easily.This removed air from the system.Hope your problem is as straight forward as mine was..
Old Apr 19, 2010 | 10:59 AM
Nitro DarkSide
that is simple, i can try
i still have the leak though.
Old Apr 19, 2010 | 12:42 PM
ripforrey's Avatar
ripforrey
Is the leak from the control valve, steering cylinder, hose? You can rebuild valve & cylinder. I've never had much succcess when I rebuild in my garage; I think you could have a hydraulic shop rebuild for about 1/2 the cost of new.
Old Apr 19, 2010 | 02:18 PM
Nitro DarkSide
What the previous owner said:
"the power steering valve has a small fluid leak at one of the hose
connections"
i posted a picture of a leak... i'm not sure it's related to the steering, but i hope so
Old Apr 19, 2010 | 07:13 PM
BritewhiteC3's Avatar
BritewhiteC3
Nitro, in the 2nd picture it appears like there is fliud at the bottom of the dust cover. . . . internal leak in control valve?
Old Apr 19, 2010 | 08:25 PM
Nitro DarkSide
i noticed that now.... but i bought the car 2 months ago, i'm still learning... do you think it's related to the power steering or something else?
thanks.
Old Apr 19, 2010 | 09:02 PM
Vetteaddiction's Avatar
Vetteaddiction
Wipe everything down and run it again, then check for leaks.
I did that and only saw fluid on the control valve and cylinder, so I only rebuilt those. If the rod on your cylinder has any nicks that catch your fingernail, it's shot - get a new one.
This link is great, Jim Shea is the Saginaw Man
http://jimshea.corvettefaq.com/?page_id=4
Good Luck,
Chris
Old Apr 19, 2010 | 09:09 PM
True Blue Vette's Avatar
True Blue Vette
Sounds like a control valve problem to me...
Old Apr 20, 2010 | 08:08 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
If you need to replace any of the components let me know. I don't recommend rebuilding a PS valve unless you've got someone around who has done it before.
Andrew
800-442-0335
Old Apr 20, 2010 | 09:48 AM
wombvette's Avatar
wombvette
Two things cause hard steering in one direction. A badly adjusted control valve, or a bad steering ram.
To Power steering problem.
