I have a TH350 Trans. Off the line is great, :eek:
Shift to second is good :yesnod:
Shift to third is :U . Lose around 2500 rpm.
I do not think that there is a shift kit. I do have a 2400 stall tq.
Without changing transmission (which I would like to go to a 6-Speed :yesnod: ) What can I do? WHat do I look for?
And it just been freaking GREAT that I have got to drive this vette all week without a problem. Forgot how great it is!
If you don't have a t350c then you can install a shift kit for 25 bucks
you will know if it is a t350c by looking around the pan if you see a elec connection with 4 connections then it is a t350(c) which is some what electrictly controled. and b&m does not make a shift kit for it
( I don't know about trans pac)
I hope this helps. :cheers:
Actualy now that I think of it that seems strange
Most people prefer the gear ratio of a t350 to a t400 although it lacks the strength.
May be there is somthing wrong. I know you don't want to here that.
:confused:
The drop off is the concern. The 'Stang got me by a car length because of the drop off. The transmission works really well. Just loses those rpms when running really hard. I really felt like I need another gear.
I guess I will have to start planning on a transmission change.
If it feels soft and you want to firm it up then transgo kit is the way to go they have kits that alter line pressure. I believe yours is just a straight up 350 not the 350c they didnt come out till afew years later. :smash: :cool: :cool:
