Wierd Power Steering Problem
Old Apr 27, 2010 | 07:01 PM
FlaVert's Avatar
FlaVert
Default Wierd Power Steering Problem
I rebuilt my control valve today using Jim Shea's papers. I purged the air, centered the valve, etc. Everything seemed fine until I went to turn left into a parking space. As I got close to full left the power steering pulled the steering wheel out of my hand and spun it to full left lock. I then had to wrestle it back to the right. Steering works fine otherwise, I can turn it to full right lock with no problems.
This doesn't seem like a centering problem to me and I didn't see anything similar in the search I did. Anybody have any ideas?
Thanks,
Rick L.
P.S. I rebuilt the control valve because it was leaking.
Old Apr 27, 2010 | 09:41 PM
cboyd's Avatar
cboyd
I am by no means an expert, but to me it sounds like maybe all the air wasn't out of your system before you set up your control valve. I just rebuilt mine, and had no issues.
Did you disconnect the steering rod from the bracket on the frame?
Old Apr 27, 2010 | 09:48 PM
FlaVert's Avatar
FlaVert
Yes, I disconnected the steering rod from the bracket when I centered the control valve.
Old Apr 28, 2010 | 12:21 AM
7T1vette's Avatar
7T1vette
The steering system needs to be 'exercised' many times from lock-to-lock in order to get the air completely out of the system. With wheels off the ground, do that 5-8 times slowly with engine OFF. Then check fluid level and add, if necessary. Now start the car and repeat the process with engine ON. Recheck fluid level and refill if needed. Now you can start it up again and check the balance of the control valve (using Jim Shea's procedure). If all is well, put the left wheel back on, set the car on the ground and go for a ride.
If you did all of the above steps and still had the wheel "do its own thing", there was likely an assembly error in the rebuild of the control valve. Hopefully, Jim Shea will read this thread and offer his advice.
Old Apr 28, 2010 | 12:46 AM
wombvette's Avatar
wombvette
Something is binding. Probably the hoses hitting the frame. This is exactly what happens when a non power Pittman arm is used on a p/s car.
Old Apr 28, 2010 | 03:37 AM
mopkop's Avatar
mopkop
Default steering full lock no controll
Check the hydraulic lines you have swapped the two aroung
J Smit
Old Apr 28, 2010 | 07:37 AM
FlaVert's Avatar
FlaVert
Is there a way to tell a non-power Pitman arm from a power? Power steering was added to this car by a PO.
Thanks,
Rick L.
Old Apr 28, 2010 | 01:51 PM
FlaVert's Avatar
FlaVert
Thought I had a pinched hose, not really pinched more of a tighter radius than I liked. Not enough to have damaged the hose. I fixed that and I am still having the problem.
The routing of the lines from the ram to the hydraulic side of the control valve appears to be correct. The hose that attaches to the top of the ram connects to the bottom of the control valve and vice versa.
I do not believe there is any air in the system. I accidently overfilled the pump yesterday and went for a long (1 hour) drive. Today I checked the level in the pump and it is correct. So I figure the fluid either went out the cap or displaced the air in the system, or both. The pump is quiet and there is no surging or noise when turning the wheel.
I am going to try the centering procedure again, but I doubt it is going to help.
One thing I noticed today is that whomever put the power steering on the car left the tie rods mounted in the manual steering holes. Not sure if this matters.
Anybody have Jim Shea's e-mail address?
Thanks,
Rick L.
Old Apr 28, 2010 | 02:38 PM
wombvette's Avatar
wombvette
Thanks,
Rick L.
The PS has more offset. Do a search here or the parts catalogs and see the difference. I will bet that the problem.
Old Apr 28, 2010 | 07:42 PM
FlaVert's Avatar
FlaVert
I did a little more searching on the forum and have figured out I have the wrong pitman arm. It is hitting the control valve when it gets close to full lock to the left. Just ordered the correct one. Relay rod is correct, but I guess it had to be to hook-up the assist cylinder.
At least the control valve doesn't leak anymore. I really didn't want to pull that thing apart to make sure I didn't assemble it wrong
Bubba strikes again!!
Thanks for all the help.
Rick L.
Old Apr 28, 2010 | 07:59 PM
08vycpe's Avatar
08vycpe
Are you sure you have the wrong Pitman arm? The reason I ask is that there are two holes in the steering knuckle for the tie rod to go into. Depending on which hole you use controls the steering ratio (fast steering front hole, slow steering rear hole).
On power steering cars you can't use the rearward hole (slow) or interference will occur. Do a quick visual check to see which hole the tie rod is installed into.
Old May 2, 2010 | 05:13 PM
Jim Shea's Avatar
Jim Shea
The manual steering pitman arm has the numbers 3829452 forged or cast on the arm. It was used on 1963 through 1976 manual steering Corvettes.
The power steering pitman arm had the numbers 3741383 usually with an "A" or "B" suffix. It was used on 1963 through 1982 Corvettes with power steering. It was also used on all full size 1958 -62 passenger cars as well as 63 and 64 full size passenger cars with power steering.
Jim
Old May 2, 2010 | 09:39 PM
FlaVert's Avatar
FlaVert
Jim
Thanks, Jim! Put the power steering pitman arm on Saturday and everything is working great.
To Wierd Power Steering Problem
