Engine trouble
Old Apr 29, 2010 | 05:20 PM
texastyler642's Avatar
texastyler642
Default Engine trouble
well, my 1977 vette boggs out everytime i step on it. i just did a fresh tune up but it still does it. i think it may be the carb but im not sure. does anyone know what is going on with my vette?
Old Apr 29, 2010 | 05:22 PM
MakoShark72's Avatar
MakoShark72
More info??? what carb?? You didnt give us much to go on...
Old Apr 29, 2010 | 05:23 PM
texastyler642
its a stock carb. when ever im at a complete stop and then step on it, it boggs out n sounds like the carb is overflowing.
Old Apr 29, 2010 | 11:19 PM
my 76 ray's Avatar
my 76 ray
It could be the accelerator pump in the carb. With the engine off look down the bore of the carb and move the linkage quickly. You should see two steady streams of gas shoot into the bore. If they are not good streams, replace the accellerator pump.
Old Apr 30, 2010 | 08:58 AM
sfallison's Avatar
sfallison
Also, check your fuel filter. Could be it needs to be replaced.
You can try running without it and see if your problem is solved.
Another prob.. fuel pump is going south.. not getting enough gas to keep up.
Old Apr 30, 2010 | 10:11 AM
7T1vette's Avatar
7T1vette
An immediate bog is usually due to a bad/worn seal on the accel pump piston. It could also be due to a clogged passage in that same system, but that is more unlikely if you have had a good filter installed. You can test this by lifting hood and removing the air cleaner. With engine OFF, look down into the primary [front] venturi, then exercise the throttle linkage to WOT quickly. You should see a strong squirt of fuel into the venturi [both sides]. If you do not, or if it is not the same on both sides, there is a problem with the accelerator pump circuit.
It's possible to change the piston seal with the carb on the car, but I would not recommend it if you are not well experienced at working on Q-Jets. If it has been many years since it has been rebuilt [if ever], do a full rebuild of the carb...making sure that all the passages built into it are blown out [pressurized air] and clear. Rebuilding a Q-Jet is not a complicated process; especially, if it is original to that car. At least, you know that it is configured properly to begin with.
To Engine trouble
