I was replacing bulbs in my gauge cluster in my 1982 vette and I turned my key on to check the seatbelt light. Well I didn't notice the stud coming off the back of the volt meter touching the shifter. Needles to say some small sparks and a tiny swirl of smoke occured. Now it looks like my volt meter is dead!!!
I tried replacing the gauge fuse on the fuse block and I looked for any burnt wires(Nothing). I'm very good at a lot of things BUT electrical is my weak point!!! Is there a fusable link or did I fry some micro circuit in the gauge???
THANKS
My guess...and it's only a guess...is that you fried one of the coil lead wires in the gauge. That is usually what happens when significant current is drawn through it. You can try to apply voltage to the gauge directly (disconnect the battery this time, please) with a small battery (anything from 1.5 volt to a 9 volt battery will do) to see if a known voltage source will drive the meter. If not, remove the meter; then carefully remove the needle and face plate [you really have nothing to lose doing this, do you?]. Look at the fine wires that connect the meter coil to the attachment posts. If one [or both] are melted and no longer connected, try to install a small jumper wire between its post and the end of the wire. If you are unsuccessful, buy a new gauge.
That worked! The gauge is OK but the printed curcuit board fried and I think its to far gone to be fixed. Now lets see who has a printed curcuit for an 82 misfire???? LOL
Try looking at Wilcox for the circuit board. They are a forum vendor and just happen to have some in stock right HERE!!!
Thanks, I ordered from wilcox because he was the cheapest but I was a little shocked at the $15 for standard ground shipping of something that can weight no more than an envelope???
Yep. Shipping will "kill" you, if you're buying small parts one-at-a-time.
It would be nice if vendors had a 'soft-pack', normal postage option for things like that. But, each package requires packing and labeling, no matter how small, and that requires a 'body' to do the work.
