YOU can NOT solve this problem -80 model
Old Mar 15, 2011 | 09:35 AM
  #61
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Originally Posted by TedH
Frame damage?
None that I can see with the car up on 4 (equal) jackstands, flat surface (well, as flat as I can find) and measurements to ground were all within 1/4 inch . I'm thinking the 1/4 inch may be with the concrete.
One of these days I'll have it put on a frame machine I guess. But for now its sitting pretty.
Old Mar 15, 2011 | 05:29 PM
  #62
C3 4ME's Avatar
C3 4ME
I remember reading this thread and the frustration it was causing. Happy to see everything finally got worked out, although, I think I'd try to get that $120 in labor for flipping the coil spring refunded.
Old Mar 15, 2011 | 09:04 PM
  #63
roy69's Avatar
roy69
I'm glad to hear you've gotten this problem solved. I'm sure you felt a great wave of relief when you saw it sitting level.
Old Mar 16, 2011 | 02:10 PM
  #64
southernflyer's Avatar
southernflyer
8th Gear
I have the same problem with my 81. However, my front suspension is not fresh (will be soon) and my car has been wrecked, burnt, and had a tree fall on it at some point before i got it. I have had it for 12 years and done the motor a couple times, tranny, rear end swap and interior. front suspension and steering are next, if that does not help then thanks to this thread i will look at the body mounts. ALSO the drivers side insert behind the rear wheel under the left rear 1/4 panel is missing since ive owned the car. It is the same piece that was shown earlier in the thread except on the other side. does anyone know where i can get this piece and can i glass it in by just pulling the tire??
Old Mar 16, 2011 | 06:59 PM
  #65
mikejpss's Avatar
mikejpss
Are you referring to #4 body mount?
If so, most of the supply vendors have them, just gotta look. I think they are pop-riveted in. Do you have the lower piece- welded to the frame?
Old Mar 16, 2011 | 07:12 PM
  #66
southernflyer
8th Gear
I will have to take and post pictures... the right side looks like it is glassed in. im not sure what i would pop rivet to....
Old Mar 21, 2011 | 10:52 PM
  #67
elealusaf's Avatar
elealusaf
good job on figuring it out. did you go with poly or rubber mounts. i had 3, 5, 5, 5 shims on body mounts 1234 respectively. and none on the passenger side. i plan on replacing with new poly mounts when i get to that on my body off. any thoughts on not putting any shims? assuming the frame is square and the body panels can be tweaked during body work to get proper door gaps
Old Mar 22, 2011 | 01:25 PM
  #68
mikejpss's Avatar
mikejpss
I used the poly mounts, from Zip....and all my shims were on the passenger side, none on drivers side. Hey, maybe it was the same guy on the production line, and they moved him from dr. side install to pass side install ? Promise you, he was screwed up when he did my car....
My opinion is: try the mounts with 2 shims each, both sides. Before you tighten back up, look at the car and take measurements. THEN, start installing/tightening back to normal. For me, the drivers side took 1/4 inch more shims per mount than pass side. She now sits like it should.
Good luck. There is a thread out there on this forum to help you install .
here is the link :
http://forums.corvetteforum.com/c3-t...with-pics.html
read and study this , it helps a great deal and will save you time/money/curse words.
