im working on my 73 small block and someone has evidently clipped the wire for the temerature sender off somewhere and i dont know where to look for it.
Can someone tell me where the wire exits a harness, which harness and what color it should be?
i know on my 75 its dark green wire that comes out in the same spot as all the alternator stuff on the drivers side... idk if its the same but good luck
Hi Charley,
Also, the end of the wire that you find still in the harness may still have the woven, insulating, cover (like a sheath) on it that the wire had originally. So be on the look-out for that too.
Regards,
Alan
