Fuel mixture is lean after headers installed.
Old May 15, 2010 | 05:46 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Default Fuel mixture is lean after headers installed.
I checked my A/F ratios tonight using LM-2 after I finished installing the hooker super comps, I've noticed that the fuel is so lean when Idle ,about 18-19, and 14.5-15 when cruising and it goes down to 13 when WOT, I know I have to do something with the idle mixture screws in the carb, but what do you think about the cruise and WOT numbers? do I have to re-jet the carb?
my engine is almost stock LS5 except 9:1 CR and mild cam.
Old May 16, 2010 | 02:17 AM
Solid LT1's Avatar
Solid LT1
I think you will need to increase main jet sizes also. What carb are you running?
I don't think it is possible to burn a 18:1 fuel mixture so your LM1 is lying to you (I'm not surprised.)
Old May 16, 2010 | 03:22 AM
c3_dk's Avatar
c3_dk
I had the same problem with my 11:1 L46 1969 engine (std 350/350 carb)after I installed headers + 2½" exhaust.
I've incresed my jets and needles.
Old May 16, 2010 | 03:55 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I'm using a quadrajet carb with a 77 primary jet and a 49 primary rod.
I thought the LM-2 is quite accurate, thats why I paid more for it!
Old May 16, 2010 | 03:56 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
what were your jet/rod sizes for before and after? .. and what was the A/F ratio for before and after?
Old May 16, 2010 | 07:29 AM
corvettedave383's Avatar
corvettedave383
the lm2 is not lying, when I start my car from cold its runs very lean, ie between 16 to 18, then richens up once it gets warmer
Old May 16, 2010 | 10:21 AM
7T1vette's Avatar
7T1vette
Where is your sensor located? Could it be positioned too far downstream which might allow the hotter headers to be burning off the excess before it reaches the sensor? I don't see how a change of headers has any actual effect on the mixture of the carb.
Old May 16, 2010 | 10:39 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
its located right after the collector, I welded it in the collector to pipe flange.
Old May 16, 2010 | 11:21 AM
Gordonm's Avatar
Gordonm
Most of the time after headers are installed it will run leaner. This is due to the fact that the headers will scavenge the combustion chamber better than the exhaust manifolds of burnt gases. Remember the engine is nothing but an air pump. More air in and out makes HP and more efficient. More air will require more fuel hence the increase in jet size. Most people don't run a wide band O2 sensor for testing the AF ratio so they just run it as is after a header install. The wide band O2 sensor can be mounted down stream a little because it is heated so the proximity of it to the cylinder head is not a crucial as it is with a non heated narrow band O2 sensor.
Old May 16, 2010 | 11:58 AM
ajrothm's Avatar
ajrothm
Hamad...just play with the idle mix screws first. I would be willing to bet you have a vacuum leak somewhere.....that's IF it's really 18-1 afr...which I doubt... Did you do a heater Calibration and free air calibration? Does the lm2 show 20.9% oxygen when the meter is on and engine off?(and not run for atleast a few hours...)
Old May 16, 2010 | 12:37 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Hi Alan, indeed I had some vacuum leak in my carb which I fixed today, it brought the idle A/F ratio back to about 16:1, and I tried to unscrew both idle mixture needles but with little/no effect on the A/F.
the carb was rebuilt by Lars so I'm sure everything inside is correct, except the vacuum leak which was my mistake (the carb was not tight to the intake flange).
my jets are 77s and rods are 48s, I'll try to jump 2 numbers to 79 and see what will happen.
I need to tweak it well before I go to the dyno shop, the guys there know nothing about carbs!, they know how to increase fuel using laptops and kept their hands clean and they don't smell gas when they go home for their wives!
Old May 17, 2010 | 10:49 AM
ajrothm's Avatar
ajrothm
Hamad.... If you screw the idle mix screws all the way in, does the engine die? If not, the you still have a vacuum leak. Ofcourse with these cars the leak could be anywhere. I would disconnect the vacuum hose that feeds the vac reservoir/headlights/hvac so that eliminates those possibilities... Just for diagnostic purposes....
I wouldn't start messing with the jets/rods yet until you make sure you have no vac leaks affecting the idle AFR.
At wot what was the afr? You said 13 but.....13 what? 13.0? 13.9? Your jetting sounds pretty close out of the box but i would prefer your wot afr around 12.8 or so.......but 13.0 would probably be fine since you live on the outskirts of hell....(during the summer anyway)
Old May 17, 2010 | 11:32 AM
lars's Avatar
lars
If A/F was correct prior to the header installation, the installation of headers will typically require a 2-jet increase in order to maintain fuel ratio. The idle mixture screws will always need to be richened when switching to headers from cast manifolds, and often the IFR's will need to be opened up to flow adequate fuel at idle and into the transition circuit.
On your Q-Jet, if you're going to be running 79 or 80 jet sizes, fuel flow at WOT will be high enough that the standard needle seat will restrict fuel flow and cause a lean-out at WOT. Make sure you obtain and install one of the larger, high-flow seats for that application.
Lars
Old May 17, 2010 | 03:52 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Here are the exact numbers :
Idle : 16.5
Cruise : 14.6
WOT : 13.5
these numbers are subject to 0.1 +/-
I didn't try to close the needles all the way in, I will try tomorrow, so the engine should tall when I do this? .. and if it continues to run that means I have air leak, right?
Lars : Thanks for the tips, I just ordered a 79 jets and 48 rods (prima
Old May 17, 2010 | 03:55 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Lars
I just ordered 79 jets and 48 rods just in case (primaries) and a high flow needle and seat set, do you think I may need to put 48 rods instead of the current 49 ones or I should be good with just jumping 2 jet numbers?
Old May 18, 2010 | 11:20 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
OK, the PCV connection was leaking and that brought the A/F up to 16.5, I plugged the carb side and it went down to 13.5 right away.
Also today I tried to screw the mixture needles all the way in and I did manage to stall the engine and eventually shut it off, so I assume the carb is leak free.
But I still don't get any change of A/F ratio when I play with the mixture needles/screws! .. why is that???
Old May 18, 2010 | 03:27 PM
ajrothm's Avatar
ajrothm
Not sure why idle mix adjustments are not affecting afr but right now I would concentrate on finding your mega vacuum leak.....going from 16-1 down to 13.5 just from plugging a vac port is huge...
You may never completely get the vac system air tight but you should get it closer then that...ultimately you want to adjust your idle mix with a vac gauge connected. Adjust the screws until you get the highest rpm/vac readings....then lower your idle to the desired rpm via the idle speed screw. Expect your idle afr to be around 14.5 or so after the engine is at full temp. I would like your cruise afr in the mid 13 range....may have to change/raise the needles to get it....
Just take it one step at a time. Find the major vac leak first....prolly the headlight cannisters or valves...pcv valve or brake booster...
To Fuel mixture is lean after headers installed.
