drive you change cam bearings, possible lifter not pumped up (hydraulic lifters?) how long engine running before knock started? oil in engine? more info!
the lower end was not touched. the motor has been running for nearly three years don't know history of the motor. she always ran strong just not strong enough so this winter put dart heads, gm hot cam(1990 oem roller block) eddy rpm intake. that really woke her up but playing with her today must of over revved it? it was a L98 motor out of a z28. dont hear anything distinct at idle but somethings knocking when revved!
you over reved it? now that really leads me to a spun rod bearing.. either way you will have to pull motor out and inspect.. at least thats where I would start
sounds lower to me? wrist pin or rod bearing maybe wont know untill i pull it tommorow. still has good oil pressure? mn-brent it"s a roller cam so no cam break in.
Lots of other things to check before condemning the motor. If you have an auto, check the torque converter bolts,bad mechanical fuel pump can knock, pull the valve covers and see if you can see anything there.
torque converter bolts tight. valve covers off everything looks normal. i took the belt off to elimanate the water pump. fuel pump??? i'll look in to that before i pull it tommorow but it sounds more terminal than that.
I usually start the engine and then shut it off to get fuel in the carb,then I remove the 2 bolts holding the pump , leave lines attached,pull the pump out a little and drop the rod and then restart and listen.
quick easy check ........pull the oil filter and pour thru a paint strainer / filter , look for shavings or babbit material. or use a white towel to strain thru...put a extendable magnet into the filter ....look for any metal particles
Did you even check the condition of the rod bearings before you put new heads, etc. on the car? If the motor had lots of miles on it, the added HP just help you wear it out really quickly. You need to pull the idler arm off the frame and drop the oil pan...then see how some of the rod bearings look.
