7 volt drain
In order to track down a battery draw you're gonna want to measure amps vs volts. There are numerous threads (many recent) on how to accomplish this.
If so, disconnect the battery, put a charger on it for a while, and try a reading at the battery terminals. If this is still the case, you've got some bad cells in that battery and it needs replacement.
Oh and I am not an electrical expert.. my handle is a reference to Back to the Future (1.21 JIGOWATTS!... NOT a gigawatt as in a billion watts.
John
1. You need a multi-meter with a 10 amp [current] scale. {not a voltage scale} Most inexpensive meters have separate lead sockets for the 10 amp current scale. The other meter scale settings are milliamp ranges and are not capable of detecting an auto battery drain; if you use one of those scales and have a battery drain, you will blow the fuse in the meter or fry it.
2. Remove the positive cable from the battery. Use duct tape to hold the door jamb switches IN so the interior lights will not be ON (and cause a battery drain).
3. Connect the + meter lead to the battery + terminal and the - meter lead to the + battery cable. (put meter in "series" with the battery circuit)
4. Measure the battery drain on the meter scale. If the drain is more than .2 amp (just a little above the "0" reading on the 10 amp scale), there is significant drain when there should be very little drain with all circuits OFF. [Note: Some digital radios have a clock reading that is ON all the time. This usually draws less than .1 amp and is not a significant issue.]
5. Assuming you measure a significant drain, pull one fuse at a time from the fuse block to see if the reading changes. If it does NOT change, reinstall that fuse and mark it so you know it has already been tested.
6. When you pull a fuse and the drain disappears, that fuse is on the circuit which has the drain. You will have to research all the wiring and components that are connected through that fuse and further diagnose which specific item/wire is the source of the drain. A drain can be caused by a defective component or a worn through power wire that is contacting ground.
7. If you pull all the fuses and you still have the same current drain, there is a minor 'contact' short in the main power line (+ 12volt) between the battery and the fuse block. Check for insulation wear-through on the main battery cable and the following feeder wire(s) to the fuse block.
8. If you still can't find the drain, call a qualified electrician to search it out.
