Composite Spring Vendors: RE: height issues
Old May 27, 2010 | 05:34 PM
Rebelrob's Avatar
Rebelrob
Yes, I was about to say, most folks, regardless of wheel size, 15, 16, 17, 18 inch or greater wheel size, still figure out the correct tire series profile so they can end up with the 27 inch diameter.
Old May 27, 2010 | 05:35 PM
Trae1976's Avatar
Trae1976
Originally Posted by Clams Canino
Well, we at least need to assume a stock 27" diamater wheel/tire combo.
How it gets there, is beyond the scope of the discuassion.
-W
I'm not running 15" wheels or stock size tires, and that has no bearing on the original poster's question:
"Which brand does not seem to make a difference?"
I know its a little hard to tell from these pics, but there is not an obvious difference. And if I were running rubber bands on 18" wheels, there still wouldn't be an obvious difference.
With original 9-leaf and 8" bolts:
With VBP 330# and 8" bolts:
Old May 27, 2010 | 06:00 PM
kansas123's Avatar
kansas123
Originally Posted by MN-Brent
VBP composite does not give you ride height issues.
I replaced a broken composite with a new one from VBP, same length bolts (8"), measured length of exposed threads before removing the old and kept the same measurement on the new. No trouble at all in maintaining the same height as before. only other difference was I chose poly rather than rubber bushings.....225 x 70 x 15 tires.
Old May 27, 2010 | 06:19 PM
vettehardt's Avatar
vettehardt
Also another thing to consider, does anybody know the stock bolt lenght on the original factory composite spring? All I see people posting about are the stock steel spring bolts. The original composite bolts might have been 8". Also who made the original composite springs for GM? If I remember right, wasn't it TRW?
Old May 27, 2010 | 06:45 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Just go with a Dual Mount Spring from Van Steele. You'll be much happier.
Old May 27, 2010 | 07:20 PM
Paul L's Avatar
Paul L
I am happy with the stock configuration. No mods needed for a Sunday afternoon cruiser. I often wonder why people try to "improve" their car beyond what GM engineers designed??
Old May 27, 2010 | 07:23 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by paul 74
You have to make the assumption that VBP, Muskegon, and the like are designing their products for 15" stock wheels based on original GM specs. Why do otherwise? The 18" rubber band crowd can find products elsewhere.
You can have you 18" rubber band wheels stock height, mine are exactly the correct stock height.
Reason for the problems is the same reason a set of expensive Hooker Headers designed to fit your C3 won't clear your spark plugs, hit your steering box or are so close everything melts and the grease inside boils and on the other side they hit your idler arm.
It's not like they just started making them, last week, space shuttle parts are their main focus and headers are just something they do on the side. That's what they do, they make headers and have been making them for decades now, the problem is they just don't give a f...
Old May 27, 2010 | 07:27 PM
MotorHead's Avatar
MotorHead
Originally Posted by muskegonbrake
We have run into ride height issues on specific vehicles, but with over 10,000 springs out there to date I think we've been pretty successful. Case in point: I have a 77 in the shop that has had one of our springs for probably 8 years and it sits perfectly level with the bolts that come in the install kit.
I know there have been ride height issues discussed on this forum in the past, they are out there and we do keep track of them. But I hear more rave reviews from my return customers than complaints (otherwise I wouldn't be in business) and have several customers with multiple cars with our spring under all of them.
If one of our customers does experience a ride height issue we stand behind the product and are concerned with our customer's satisfaction. I would rather take back the spring than have an in-correctable ride height issue and a dissatisfied customer. Let me know if you have any questions.
Andrew
800-442-0335
If this is how you operate you deserve everyone's business, you will get mine that is for sure
Old May 27, 2010 | 07:49 PM
69'Silver's Avatar
69'Silver
I was able to achieve this ride height with a VB&P rear composite and 550# front springs
Old May 27, 2010 | 08:21 PM
bt57's Avatar
bt57
Andrew
800-442-0335
meaning if I send my spring back that has 200 miles on it and never was low enough even with 9 inch bolts you will refund my purchase, yes i did purchase it from Muskegon brake
Old May 27, 2010 | 10:20 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Your car looks really good! How long are your bolts on the rear and which spring rate?
Old May 27, 2010 | 10:34 PM
CheezMoe's Avatar
CheezMoe
Lot's of good replies and opinions guy's. Thanks to Andrew from Muskegon for chiming in. I guess the rest of the vendors cant be bothered. At this point I have cut the exhaust to refit it around the spring. I really wish I hadn't, but now I might as well test drive the new spring. Van Steel posted in Grumpy's thread that they would take the hypercoil back after I drove it if I was dissatisfied. So we will see where that goes. It seems from the reply's in this thread the VBP users are the most satisfied but still wonder about the whole design of thing.....seems like it would be pretty easy to reduce the arch on the spring a little and solve the problem, and allow us to easily lower these cars a little while getting the ride and handling improvements from the composite.
Old May 27, 2010 | 10:49 PM
  #33
Goody's Avatar
Goody
Pretty simple actually, unlike you many people are not content to settle for what the bean counters would allow the engineers to accomplish based on profit margin. A mass produced car is more about compromise than anything else and after having experienced new technology some people desire better older cars by bringing the two worlds together.
The joy of free will....
Old May 27, 2010 | 10:50 PM
  #34
alswagg's Avatar
alswagg
I bought my rear TRW spring from Muskegan Brake last summer. The rear does sit higher than normal. maybe 1" I just thought you had to get the longer bolts when going with the higher spring rate. I was going to order the 9" bolts and install. I really did not think of it as a big deal. Al
Old May 28, 2010 | 07:48 AM
  #35
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
As always, this topic brings up a spirited discussion. I have read all the responses and I take them in the spirit that they are offered. I know the company has reviewed altering the spring in the past, but it was years ago. It sounds like it is time to do so again. And again, if you have any questions or concerns please call me.
Have a great holiday weekend everyone, and take a moment to thank the people who gave so much that we could have a three-day weekend. Seriously, thank a Vet. I mean a member of the armed forces, not your Stingray
Andrew
800-442-0335
Old May 28, 2010 | 08:57 AM
  #36
Clams Canino's Avatar
Clams Canino
Let me ask you this... was the previous review because the spring was making the cars too low?
I for one implore you to get them to review this. If "customer satisfaction" doesn't move the bean counters to do so - try the words negligence and liability out on them - that usually lights a fire under even the widest of rumps.
Like I've said... there's some fairly serious legal exposure with those longer than stock bolts. And now that all this has been noted in this thread (again), it part of the "permanent record" as such too.
I know your heart is in the right place, now go get 'em
-W
PS: It would be nice to see VBP jump in here too....
Old May 28, 2010 | 09:09 AM
  #37
Clams Canino
Originally Posted by Van Steel
The VBP springs are made in house here in FL. The Hyperco springs are made by the OE manufacture for GM which is LiteFlex. LiteFlex has made the springs since day 1 for GM. They are US Made as well.
Hi there Van Steel
Do you know what bolt length comes standard with the VBP springs?
And ditto with the Hyperco/LiteFlex units?
Do you (or anyone) know what year GM switched over to the composite springs?
We are just trying to determine who is high - and by how much overall.
So far only Andrew from Muskegon (TRW spring) has come in to help.
-W
To Composite Spring Vendors: RE: height issues
Old May 28, 2010 | 09:56 AM
  #38
Paul L's Avatar
Paul L
Hi there Van Steel
-W
You will of course get a reply from the experts but I believe you will find that the VBP bolt length is 8".
The composite spring was introduced in 1981.
Old May 28, 2010 | 10:21 AM
  #39
...Roger...'s Avatar
...Roger...
I think your right and if you were happy with your ride height it appears , from the position of the nut you had the option to go up OR down. Nice !
Old May 28, 2010 | 11:19 AM
  #40
mrvette's Avatar
mrvette
Because we DO and CAN, obviously....
