Drain Hole?
Old May 30, 2010 | 11:41 AM
Apocolips's Avatar
Apocolips
Default 1970 Plenum Door.
OK, I’ll try this question. Is the plenum door in the passengers’ kick panel supposed to be open or closed in the OFF and MAX A/C position, or, should it be open?
Old May 30, 2010 | 03:11 PM
Apocolips's Avatar
Apocolips
ttt
Old May 30, 2010 | 03:23 PM
...Roger...'s Avatar
...Roger...
In Max it should be closed so you recirculate the air in the car.
Old May 30, 2010 | 03:28 PM
Apocolips's Avatar
Apocolips
That stiinks, mine opens when you start the car in the OFF or MAX A/C position then closes when BI-Level and Vent is selected.
Old May 30, 2010 | 06:51 PM
Hammerhead Fred's Avatar
Hammerhead Fred
In MAX AC the lower door should be open and the upper (outside air intake ) door should be closed which then allows recirculation of the cooled cabin air back into the fan intake.
Old May 30, 2010 | 06:57 PM
Apocolips's Avatar
Apocolips
I haven't checked the upper door but the lower "kick panel" door is open when power is off or in MAX A/C. I checked it today because there was a lot of hot air coming from there with the system in the off position.
Old May 30, 2010 | 07:50 PM
...Roger...
Sorry ... brain fart....Fred is correct the door "opens" in the MAX position,I think its actually called a "recirc" door in the manuals.
Old May 30, 2010 | 09:30 PM
Apocolips's Avatar
Apocolips
I appreciate the help. That's one less thing I have to try and fix. Ya'all have a great weekend!!!!
To Drain Hole?
