Are you replacing just the T/A or the T/A and bearing housing?
Either way, you need to remove the spindles to get at the bolts that hold the T/A and housing together. You can see the heads of the bolts in the picture looking at the spindle.
I took mine apart by installing the nut only on the spindle backwards, supporting the T/A so the spindle was free, and rapped it with a 5lb brass hammer. Came right out. Had to press the bearing off the outer spindle. Keep the shims and other parts in order.
The bearing carrier complete with spindle can be removed from the TA as a unit. You have to take the yoke off first, which you've already done.
Next remove the p-brake shoes and you can access the 4 nuts that hold the bearing carrier to the TA. The studs stay with the TA and go through the bearing carrier so it can be hard to get them apart if they have rusted.
Just take it to a good mechanic (that has rebuilt C3 trailing arms before) and let him/her do the job. You did all the hard work. Now that it's off the car, it's a "piece of cake" with the right tools.
I'm not even sure how far i would have to travel to find a good mechanic as well as a capable C3 mechanic....but i have a feeling there is nobody even close that would fall under those titles around here.
The bearings seem VERY smooth even though the photo makes it look a bit dirty. I was hoping i could just take the assembly apart as a whole and bolt it to the new T/A without messing with it at this time...
When i get the car running well and have time i can come back and fix it all up nice and purdy like.
those bolts holding the whole assembly on i have a feeling are going to be a pain seeing as how rusted they are...
Zwede described it exactly if you only want to do the TA's. Getting the parking brake shoes out and back in can be a real pain with the spindle in place but it can be done. If you do not want to rebuild bearings at this time get new TA's and 8 new bolts and nuts to bolt them back together. Bolts are unique with shoulders. Should come from same place you get TA's. good luck, mike...
When taking the T/A's off i took a look at the parking brake lines and noticed they weren't even hooked up in the rear...
I'll give taking the P brake apart a try and see how that goes.
If not i guess i don't see why a $250 tool is needed to get the spindle out. Like stated above why not just put a cap nut on it then whack it with a hammer...? I'm sure there's far more risk but it's been done and worked i'm guessing.
I was taught not to use a press or those plate spindle removers. I saw mine removed with a spindle knocker [Ecklers] and a BFH. Hold TA on bushing end with opposite end on floor and give it a whack. He did this on a wooden floored shop so no damage to spindle when it came out. Setting up bearings is something I left to him. How mine came out. mike...
I assume you're in Champaign
Give these guys a call, not too far from you and they do a lot of rear spindles etc. Supposed to be pretty good with good prices.
VTECHCORVETTE
Stillman Valley, Illinois
815 262 1681
VTECHCORVETTE
815 262 1681
Yeah i'm in Champaign....and like I thought they're a minimum of a 3-4 hours drive one way.
I can tell you i'll attempt this till i break something before i drive 4 hours to a shop.
But it's good to know where the nearest one is for when i do really need them.
I had to order some stuff online so i added a spindle knockout tool just to have.
I'm wondering if i use the knockout tool to knock the spindle out to have better access to the parking brake and bearing carrier will i need another special tool to get it back in? Even if i don't touch the bearings at this time?
I would never reuse a bearing after knocking the spindle out. Each whack of the sledge will slam the rollers into the race.
I use a press (cheapo harbor freight 12 ton) to assemble the spindle/bearings. Don't know what you'd do without a press.
Did you still need that bearing setup tool along with the press?
I know everyone said to do the fronts while i had them out. I took them all apart and damned if they looked brand new still. re packed them with new grease and didn't bother replacing the races or bearings until i knew something was wrong with them...
I just don't want to knock the spindle out if i have to order another tool($75), wait another week for it to ship, then maybe even find a press to use the thing, just to get the spindle back on the assembly. They said above this all can be done without messing with the spindle...even if it is the harder way it seems like i'm creating too many projects all at once and will never get the car back on the road this summer.
I wondered how and why you completely avoided using the set up tool and until I read this: "I like grinding out the inner bearing so that it is a light press fit." gack. Not for the average rebuilder.
Heh heh... yeah, I know. The inner bearing elicits strong feelings. I do want to make clear that I only remove a tiny amount of metal. It's still a press fit, NOT a slip fit. You just don't need a 10 lbs sledge to get it off.
I just got done re-doing the trailing arms (the work on the webpage was in 2004). Reason I had to redo it was that the spindles turned out to be cheap chinese imports and were twisting. The inner bearing showed no signs of spinning on the spindle and was in perfect condition.
If you have an interference fit then you can use a commercial grade propane heater to heat up the outer part. I did this when I rebuilt my transmission...works great.
I had planned to just pump some grease into the hub on my 72 and my spindle looked a lot like yours before I took it apart. I tried reversing the nut and tapping it out but that didn't work. Finally got it apart but it was obviously junk. I didn't want to do the job twice so I had VTech rebuild mine with new axles.
Keeping the rear wheels on seemed pretty important so I bit the bullet and had a pro rebuild the hubs after I replaced the bushings. I didn't have to buy new arms so I added a little clearance by having the e-brake cable bracket welded to the top of the arm.
