Re: Compressor for garage suggestions... (joeveto)
I have a 5 hp two stage mounted on a mobile 25 gal tank. The plug in (110v) tag said that this compressor should have it's own dedicated curcuit. I am wiring a new garage as we speak (24X48 detached) so I can do that.
However, I have a 60 gal tank that was given to me that I will plumb with a quick disconnect for those jobs that will require high volumes of air. This tank will be permanantly mounted to the floor.
If you have the funds, go with the 60 gal tank with the 2 stage motor. The oil less models are loud and obnoxious. Grinders, DA sanders and paint guns can require large volumes of air AND pressure. Good luck!
Weasle :cheers:
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Re: Compressor for garage suggestions... (L. Jackmin)
I have the 175 psi 2 stage black ( Professional ) Craftsman and I think it is pretty good. It will run any tool but you will give it a workout with the sanders die grinders etc.
I have a sandblasting cabinet and it is adequate for that but I think it is on a little too much. One thing about this model is that is oil less but it is not too noisy ( You can hold a normal conversation beside it )
If you don't want to wear ear-plugs while your compressor is on, make sure you get an "oiler" compressor. Of that type, the quietest I've ever heard is made by Quincy. They do make 110-volt units and they last forever - many times longer than your garden variety Craftsman or Home Depot special.
Joeveto - Another thing to remember is the larger sized models are stationary and most of the manufacturers highly suggest you bolt them to the floor to dampen the vibration. So if portability is an issue, that may affect your decision.
Also, from what I'm experiencing now, I highly recommend setting up a good filtration system. I've found that setting up the compressor with iron pipe and the appropriate dirt traps, filters, regulators, etc. really makes life easier. The Craftsman manual had a good picture of how to set this up.
I spent around $150 to setup the filters, etc. but I feel it will benefit in the long run by not having dirt or water making it into my tools.
