Help! Missing vac Tubes?
Old Jun 26, 2010 | 07:02 PM
peterek's Avatar
peterek
Default Help! Missing vac Tubes?
Guys
I'm a new owner of 81 Corvette, Don't know much about old cars, Need your help
I removed air filter pan and found out that there is a long screw inserted in a tube in a back of carburetor. Do you know what that would be? why it is there? should it be connected somewhere? 1st pic
Also there is a 4 way connector that goes to air filter pan, one side goes to the pan, another side goes to air tube, and there are two pins that are open, shouldn't they be connected to something? Please take a look at 2nd pic, ( the red plastic piece)
Old Jun 26, 2010 | 10:20 PM
dburgjohn's Avatar
dburgjohn
looks like someone has started removing the polution controls. There are valves in the air intakes that cause the car to pull hot air off the manifolds to help the car warm up when it is cold. You should get a shop manual to get info on how to hook up the hoses of you want them repaired.
Old Jun 26, 2010 | 11:48 PM
lars's Avatar
lars
The pugged tube is the manifold vacuum source for the air cleaner hot air flapper door operation and controls. The "T" connection on the air cleaner is also part of this system. Someone has removed and disabled this system to prevent the air cleaner doors from closing and providing warm air to the carb under cold outside air conditions.
Lars
Old Jun 27, 2010 | 02:26 AM
c3corvettes's Avatar
c3corvettes
One of the connectors on the red thermal vacuum switch connects to the EFE valve that is located on the base of the passenger side exhaust header. It is connected via a hard pre-bent tube that also has a hose hooked to it.
Old Jun 27, 2010 | 07:20 AM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
http://earchitect.50megs.com/corvett...s/eng-vacc.jpg
This is a schematic of the L82. I believe the L81 to be the same.
Gary
Old Jun 27, 2010 | 11:40 AM
fauxrs's Avatar
fauxrs
Gary
The schematic is for the 78 so no warantees on how applicable it is to the 81
Old Jun 27, 2010 | 12:26 PM
81 is shown the same as 78 in the Chilton book. Different bore and different compression than the l82.
http://www.motorera.com/corvette/index.htm
Old Jun 27, 2010 | 02:25 PM
lars's Avatar
lars
Different bore than the l82.
A Chevy 350 with a different bore than another Chevy 350...? Goes to show you how screwed up Chilton's is - don't use Chilton's books - use the GM Shop Manual.
Lars
Old Jun 27, 2010 | 03:29 PM
The bore and compression came from the Corvette History Site.
To Help! Missing vac Tubes?
