Timing
Old Jun 28, 2010 | 12:05 AM
Richard Cooper's Avatar
Richard Cooper
Default Timing
I want to put in a new distributor. My new dampner only has a slot milled in it. There no numbers. When the pointer is aligned with this slot is that 0 degrees? I know I have to be on the compression stroke and I will determine that with a rubber hose and fitting in the spark plug hole and when I feel air coming through the hose I am on compression. TIA.
Old Jun 28, 2010 | 01:38 AM
73StreetRace's Avatar
73StreetRace
Yes, the milled slot is supposed to be the 0° mark.
BUT, if it's a new damper, you should check that this mark really matches the #1 piston TDC.
Every timing adjustment you'll do later will depend on this basis.
If it's false and it sometime is or manufacturers wouldn't sell adjustable timing pointers, your timing will be false by the same amount.
You can check that easily by using a piston stop, it's cheap and only takes a few minutes :
http://www.summitracing.com/parts/SUM-900189/
If you don't know how to use it, feel free to ask...
While you're there, I also strongly suggest that you buy a timing tape corresponding to your damper diameter :
http://www.summitracing.com/search/?...g%20tape&dds=1
This will make your future timing adjustments much easier, especially if you don't have a dial back timing light.
Old Jun 28, 2010 | 11:41 PM
terry82's Avatar
terry82
i would look at the old dampner .and see if the slot and the key way on the new one are close to where the old one are.
Old Jun 29, 2010 | 09:35 AM
08vycpe's Avatar
08vycpe
The suggestion by 73streetracer about using timing tape is a good one. Alternately you could buy a dial back timing light which is a good thing to have as well.
Old Jun 29, 2010 | 12:03 PM
7T1vette's Avatar
7T1vette
Because the piston movement near TDC is very gradual (a few degrees either way of TDC), the best way to get an accurate TDC position is with the piston stop tool. There are other 'backyard garage' methods and they will get you within a couple of degrees of TDC, but the stop tool is one the best ways.
To Timing
