side pipes question
He didn't have any in stock before I had to decide (so that I had some pipes for my R&R back to the states) so I went with the more expensive Hookers. They look GREAT.
I also went with the STS baffles (google STS baffles). They are a spiral type baffle that I think sounds much better than glasspacks.
And requisite picture (sorry, I have already posted this one today, but it shows the pipes the best (closest I've got, and in best lighting):
http://forums.corvetteforum.com/c3-t...t-quality.html
Lars
As for me, I had not read your post as you assume we all do, and went ahead and bought them. Had no problems at all. The pipes looked great (or maybe I'm a noob that will never win a car show, not that I care). Mounted on fine. No interference with chassis or engine components. Welds might not be "seam-less" but they look fine to me.
http://www.sweet-thunder.com/corvett...pes_68_74.html
They are the same style I have. Mine are stainless steel.
http://forums.corvetteforum.com/c3-t...ew-wheels.html
After reading a lot of Threads on the subject and doing the maths, I have decided to go with Josh from Superpowers.
I live in Aus and have to make sure what I get is value for $$$$, having all my emails and questions anwsered quickly by Josh, has made the choice easy.
Here are the headers mounted to the engine after being “tweaked” a bit:
The sidepipes were mounted on custom made standoffs to make the pipes run level and parallel to the frame rails:
I was lucky to be working on this with the body off the chassis – I can’t imagine doing this amount of work from the bottom of a complete car:
With the system mounted to the chassis, I then lowered the body back on the car – pipes and headers now look and fit well, but I wouldn’t want to do it again:
I really want sidepipes, but I don't like the looks of the stock(ish) pipes. More specifically, I love the way the Hooker sidemount headers bring the primaries all the way out to the side of the car. I haven't seen any other setups that do that. Do they exist?
For standoffs, I used the Hooker hardware, but used a set of sway-bar bushings/spacers instead of the cheap rubber ones that came with the kit. Also, because the primaries are so large, it was hard to get the header bolts started -- a lot and trial and error and experimenting with different bolt types . . . ended up using allen head bolts.I don't remember really having any fitment issues, but I'm fairly new to wrenching and probably just don't know the difference. They sure look and sound good though.
EDIT: Just read your previous note . . . get some heat shields to protect your legs. I bought the steelshields.com "plain and simple" and are SS so they match the Hookers great if you go the SS route.
If I'm gonna have to break out the hammer and torch (I don't have a porta power, but I do have a hydraulic jack and a log chain) I will feel much better about it at half the cost.
Lars
