Rust under interior panels?
Old Jul 2, 2010 | 09:17 PM
vettespd00's Avatar
vettespd00
Default Rust under interior panels?
I am in the process of taking some of my interior panels off my 74. When taking the pieces off the ceiling areas behind and in front of the T TOPS rust flakes came off with the pieces. if you smack it with your hand some flakes stick to my hand. the whole this isnt rusty just certain areas. there are no holes and i dont see any weak spots so i am guessing this isnt something I should worry to much about. I am guessing this is caled the bird cage i hear so much about. I was thinking of just sanding it down and spraying some heavy duty rust preventing spray paint on before putting new interior pieces in. just what some opinions thanks
Old Jul 2, 2010 | 10:03 PM
72LS1Vette's Avatar
72LS1Vette
If you can post some pictures of the areas in question you will get better advice. Rust flakes could be minor or major problems. You have to hit the rusty areas with a pointed hammer to determine of there are any holes or weak spots. A visual inspection isn't enough. Good metal will 'ping' when you hit it. Spots that are about to become holes will 'thud' when you hit them.
Rick B.
Old Jul 2, 2010 | 10:44 PM
vettespd00's Avatar
vettespd00
[IMG][/IMG]
Old Jul 2, 2010 | 10:45 PM
vettespd00's Avatar
vettespd00
[IMG][/IMG]
vettespd00's Avatar
vettespd00
i posted pics, first time doing it lol.
Old Jul 2, 2010 | 11:08 PM
vettespd00's Avatar
vettespd00
forgot to ask, it seems strong to me in this area but if i get to looking at it and its bad what options do i have? can i repair it easy or is this major?
Old Jul 2, 2010 | 11:51 PM
7T1vette's Avatar
7T1vette
I would use a wire brush wheel on a drill or air gun to 'dig' that rust off the surface. That will tell you if it goes deeper than the surface. If you can clean that up with the wire brush, clean it off well with a solvent then spray a coat of zinc chromate self-etching primer on it. This will seal the surface and prevent further rusting.
Obviously, there is moisture getting in at the roof panels...probably via leaky top seals. Investigate, find and fix the sources of leakage so that you don't end up with a real horror case in a few years.
Old Jul 3, 2010 | 05:01 AM
vettespd00's Avatar
vettespd00
awesome. i was laying in bed and couldnt sleep thinking about this so i went out side with a steel punch and started smacking at it to see if it thuds or pings lol. it seemed very strong and pinged nothing went through and no holes were created. so i will sand the heck out of it tomorrow and spray it when i get it in the mail.
QUESTION look at these links which one is the correct one to buy or are they both the same? i dont want to buy the wrong thing because i am probably going to buy a few cans for future ref. and I WANT THE BEST you can buy to prim and put a strong barrier to stop further rust. ALSO as far as leaking i am putting all new stripping on the car as well
here are the links
http://kustomaccessories.com/Yellow-...B000CPCRI6.htm
or
http://www.summitracing.com/parts/VHT-SP306/?rtype=10
Old Jul 3, 2010 | 08:07 AM
jnb5101's Avatar
jnb5101
i'd recommend a rust converter. it's a phosphating agent that converts the iron oxide to iron phosphate, which is a compound that will not oxidize. apply with a brush and work into all crevasses, then prime and paint. eastwood (and others) sell it.
zinc chromate is the best, but i don't think that "real" chromate is available since the epa hired the last batch of attorneys. it is dangerous stuff. the people that restore the aircraft at the smithsonian in dc use(d) chromate and epoxy. they told me that if applied properly, "it will never rust again"!
Old Jul 3, 2010 | 09:51 AM
Alan 71's Avatar
Alan 71
Hi v,
If you'd like to try some paint that still has zinc oxide in it it looks like the aircraft industry still uses it as jnb mentioned.
Try a google for aircraftspruce.
Although the factory used a zinc paint there are other good possibilities as have been mentioned.
Regards,
Alan
Old Jul 3, 2010 | 02:59 PM
7T1vette's Avatar
7T1vette
The military uses zinc chromate for about everything that needs rust protection. It is greenish in color, but is a really good primer for any following coat and does a great job at preventing further rusting.
If you have remaining rust on the surface after cleaning, a rust converter would be appropriate, THEN use the zinc primer.
Old Jul 3, 2010 | 03:55 PM
MIKE80's Avatar
MIKE80
I wire wheeled my birdcage and painted it with POR-15.
Old Jul 3, 2010 | 04:00 PM
vettespd00's Avatar
vettespd00
wow i never new stuff like the eastwood products existed. i think i will go with the pre cleanser first then the converter then finish with the capsolator black paint when done.
To Rust under interior panels?
