71 Vacuum Tank
One is the vacuum system.
It all works well but the wiper door does open and close on startup or after a heavy acceleration.
Have read numerous threads and have been following some of the tips from Roger and others.
I now have a number of items to replace to try and fix it but am more concerned that there is no vacuum tank where the AIM shows one.
Should all cars have one ?
I dont even see evidence of where brackets may have once been.
Probably more important than the tank is the vacuum check valve in the main line off the intake manifold. If it is not there or defective, that stuff may, or may not, work at various times.
P.S. If you need a tank, your best option is to buy a good one at a Corvette parts swap meet.
Yes your car should have a vacuum tank. It fits above the vapor canister under the driver side fender surround sort of between the power brake booster (if so equipped) and the horn relay. The brackets are actually welded to the tank and bolt through (3 I believe) the fender well. I have seen a few for sell from time to time on internet auctions.
Scott
Finding one in Australia may be a bit more difficult so I may buy a generic one or try and make one.
I saw it mentioned that you could possibly make one from PVC pipe and then fit some brass outlets.
I assume there are no valves etc its just straight through as the check valve is doing the sealing.
So having no tank could be the cause of the door opening under hard acceleration then ?
Regards
Craig
