Timing Question
Old Jul 8, 2010 | 02:11 PM
redman76's Avatar
redman76
St. Jude Donor '09
Default Timing Question
I set my timing according to Lars and John Hinckleys white papers -- I have 36* all in before 2800 RPMs, but that leaves my initial at 25-26*. Car starts fine, idles fine and has good off-idle throttle response with no pinging. The 25-26* initial just seemed higher than I was expecting. Also, is 10-11* of centrifical good or do I need a broader range? I've read that I can change the bushing to adjust the range but was more curious what the impact was with the way it is currently setup.
My distributor is GM HEI upgraded with Pertronix FlameThrower coil, electronics and weights/springs kit.
Old Jul 9, 2010 | 10:50 AM
lars's Avatar
lars
A 10-degree advance curve is certainly a little short, but can be made to work just fine. If the car has a big cam, the short curve is exactly what you want, but a smaller cam tends to like a little less initial timing.
You might want to install some stiffer springs just as a test - see if the initial timing comes down with stiffer springs installed. If it does, the initial timing is simply a matter of some of the centrifugal timing coming in at your idle rpm. You can then gain some range back by using some springs that brings in the total timing just a tad higher, say 3000-or-so.
If you car runs well with the advanced intial (and most will), I would keep the curve and simply use a vacuum advance with a very short advance range - run a vacuum advance with about 10-12 degrees of advance. This will get you a vary nice setup with excellent throttle response.
Lars
Old Jul 9, 2010 | 11:28 AM
redman76's Avatar
redman76
St. Jude Donor '09
Thank you Lars, that is EXACTLY what I needed to know. My cam is not that big, but everything seems to be working fine . . . just didn't want to leave anything on the table.
Lunati 60102L Advertised Duration (Int/Exh): 256/262
Duration @ .050 (Int/Exh): 213/219
Gross Valve Lift (Int/Exh): .454/.468 LSA/ICL: 112/108
RPM Range: 1000-5500
Old Jul 9, 2010 | 02:15 PM
lars's Avatar
lars
As long as you don't run into low-rpm detonation there is nothing wrong with bringing the timing in quickly. Your car should perform very well as set up - just make sure it doesn't knock if you lug it around.
Lars
Old Jul 9, 2010 | 03:01 PM
Maymyvetteliveforevr's Avatar
Sorry to highjack this thread redman76, but if I may ask Lars a question?
Lars do you have or know of a good write up on how to rebuild the 75" HEI distributor properly?
To Timing Question
