Hi all,
We are restoring a 68 that was pretty much as original save some minor parts, starter,alternator, etc. It is a 390 hp 427 auto convertible and has been in the current , also the third, owners family for years. During the investigation we found all the major numbers to be correct although rust claimed the original fuel tank the owner removed and preserved the factory build sheet from the original tank. The dillema we need help with is the exhaust manifolds. According to the NCRS guide and reference manual all 68 and 69 Vettes had air pump emissions systems. This car has no trace of these parts and in addition the exhaust manifolds carry the correct casting numbers and august and september 67 casting dates but they are not drilled for the injection tubes. Any information to help clear this up will be greatly appreciated.
Best regards,
Mike
Im not the smartest vette person out there, but i do not think the big blocks came wirh smog pumps, only the small blocks. And or depending on what state it was delivered to.
All 68 and 69 Corvettes had A.I.R. irrespective of engine option or delivery destination. No known exceptions.
It's pretty common to see all signs of the system being removed. That's a shame, as replacing it will cost around $1500.
If indeed it still has the original engine, then somebody changed the manifolds when they removed the smog. Kinda silly when all they had to do was screw in some brass pipe plugs.
mine have the holes plugged, and after checking I figured out the dates were not consistent with them being the original ones anyway.
I will say this - saw a nice smallblock 69 (or 68) at an NCRS regional and was kind of surprised to see a car being judged that was missing the AIR pump. I saw the same car a couple of weeks later wearing his top flight ribbon. I asked the owner and he said that the car was so good everywhere else it made top flight even after taking the deduction for entirely missing AIR pump.
The exhaust manifold castings would have to be machined for those AIR tube fittings. Now, mind you, I don't know if this could be the case [or not], but perhaps those manifolds were purchased as "over the counter" replacements. Were there other '68 Chevy vehicles that used those same manifolds but did not require the AIR pump?
Thanks for all the help and information. We have located a correct pair of ex manifolds, now we need the rest of the parts. from the pump and mounting brackets down to the injector tubes in the manifolds.
Best regards,
Mike
Mike
You might want to consider installing the system as inactive. Forget the tubes inside the manifolds and disable the pump so it just spins freely. No NCRS judge will know it is not working unless you tell them.
