1980 L82 Radiator leak
Old Jul 19, 2010 | 11:08 AM
ndmick's Avatar
ndmick
Default 1980 L82 Radiator leak
As I`ve stated my 1980 L82 radiator has started to leak ,I would like to replace it and keep it as close to OEM as possible where do I find a correct radiator?Is Dewitts the place I want to use?
Old Jul 19, 2010 | 01:21 PM
speedreed8's Avatar
speedreed8
that would be the logical choice (dewitts) their direct fit aluminum radiator would
be a nice upgrade, call them i'm sure they can disguise it with special paint to look
oem, but would cool much better. by the time the shroud and brackets are installed most people wont know the difference.
Old Jul 19, 2010 | 01:30 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have your original radiator cleaned/recored. the radiator shop can fix the leak while they're at it.
Old Jul 19, 2010 | 07:29 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
Actually, Ive got one I replaced with an aluminum one. If you want my old one let me know. Had a shop check it and they said it was fine.
Old Jul 19, 2010 | 10:06 PM
7T1vette's Avatar
7T1vette
It will cost you more to repair one that had stop leak in it than just getting yours recored and checked out. A recore will cost you less than half what a 'direct-fit' new radiator will cost you. And, if done properly, will be just as good as a new unit. DO NOT let them use some chinzy core to do the job; tell them you want a core equivalent to the original unit.
Old Jul 20, 2010 | 08:00 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I replaced mine with a brand new, not a re-build one and it was only 190.00 new in the box, exact same has I had , worked like a charm and it was cheap! Ron
Old Jul 20, 2010 | 08:09 AM
thegazman's Avatar
thegazman
Default thegazman
Unfortunately, a good radiator shop is not always easy to find.
Old Aug 5, 2010 | 10:01 AM
dbguettl's Avatar
dbguettl
Ron, where did you get the $190 radiator?
To 1980 L82 Radiator leak
