rear susp. pic. help needed
Old Jul 22, 2010 | 09:34 PM
2box's Avatar
2box
Default rear susp. pic. help needed
I am rebuilding the rear end (1979) I have this problem that when I was trying to install the fiberglass spring, I have a very small space between the T/A and spring. As I understand it from the instructions I am supposed to raise the spring to meet the T/A but mine are so close together that I can install the bolt that holds it in place without having to raise the spring. I was also trying to leave the nut that holds the bolt in place at the very tip of it, because for what I have found out the less threads that show the lower the car will seat, But I was not able to do that 'cause as You can see in the pic I still have to thread that nut a lot so that it starts tightening both parts. I have put in adj. strut rods and shortened them to the size of the ones that came with the car. Help please
Old Jul 22, 2010 | 09:50 PM
Frogday's Avatar
Frogday
The bolt looks pretty long. What size bolt are you using?
Try putting the wheel back on the car and then put it back on the ground to see what kind of clearance you have. If it is too low, get shorter bolts.
Old Jul 22, 2010 | 10:08 PM
Mick 72's Avatar
Mick 72
"because for what I have found out the less threads that show the lower the car will seat" This does not seem to be a correct statement. The closer the spring is to the trailing arm the lower the car will be. Look back at you photo. What that bolt does is pull the spring to the arm when you tighten the bolt. What you are doing is trying to straighten the spring and take out a lot of that arc. You may still need to get at least 2" shorter bolts
Old Jul 22, 2010 | 10:15 PM
2box's Avatar
2box
The ones I am working with are 8". And I try the wheel but after I take it off the car the same thing happens.
my 76 ray's Avatar
my 76 ray
Is that jack stand under the trailing arm so that it's holding the trailing arm up? I think the trailing arm should be hanging unsupported.
Old Jul 22, 2010 | 10:18 PM
2box's Avatar
2box
Did I get it wrong then. I saw a thread that said that If You had 8"
bolts and the car was sitting to high You could take care of this by using 10" bolts.
Old Jul 22, 2010 | 10:20 PM
82CEtuner's Avatar
82CEtuner
Thats pretty much how its suppose to be for a fiberglass spring it does not flex much, the 8 inch longer bolts are so you can lower it, if you dont want it that low simply tighten the bolt more, that is how you adjust your ride height, nothing is wrong here.
when the car is on the ground it will seat in there just fine, and if you need to raise the car tighten the bolt more, if you want to lower it, loosen it.
2box's Avatar
2box
It is not. It is under the frame. The T/A's are hanging unsupported.
Old Jul 22, 2010 | 10:26 PM
2box's Avatar
2box
I was under the impresion that there had to be tension here just as in the old 9 leaf. Right now there is a lot of play, I have seen some pics where the bolts that hold the spring are tight and straight and I was trying to get that in mine and I just can't. The pics I have seen are of cars on jacks.
Old Jul 22, 2010 | 10:28 PM
82CEtuner's Avatar
82CEtuner
no this is a wrong statment, the closer you pull the trailing arm to the spring the HIGHER the car will sit, its when you LOOSEN the balt and the traling arm goes up away from the spring that the car lowers.
This is perfectly normal when the vehicle is not under its on weight weight a fiberglass spring. what will happen when the trailing arm is set down onto the grond the car will settle down on top of it pulling it up back into the fender well, and as this happens it will go till the point that the spring compresses and depending on how far the bolt is tightened or loosened is how it will sit.
Old Jul 22, 2010 | 10:32 PM
82CEtuner's Avatar
82CEtuner
Mine is the same way, These springs are not under compression when the vehicle is suspended, that is a unique feature with them, you can take the suspension apart without worrying about the spring being compressed.
The pictures were probably of cars with six inch bolts (stock) and they probably had them tightend up not knowing that it probably jacked the car up 3 inches or so until they dropped it on the ground.
Trust me set up the other side the same way, leave yourself about a inch 3/4 of bolt on each side (use a tape measure on the amount of bolt you have extra to make sure the ride height is the same on both sides, and then drop the car down on the ground, drive it forward and backward about 20 feet to let it settle and see where the height is. and if you look everything will be seated and sitting just fine. then if you dont like the height LOOSEN the bolt to drop the car, TIGHTEN it to raise it
Old Jul 22, 2010 | 10:45 PM
2box's Avatar
2box
Thank You 82CETuner. Could You please tell me, How did You get Your bolt and bushings to seat straight. I mean one bushing on the top cup washer and the other in the hole in the spring with the car on jacks and no tension. Thanks for taking the time to answer..
Old Jul 22, 2010 | 10:58 PM
Rebelrob's Avatar
Rebelrob
Are you talking about the space you see between the bolt rising up inside the T/A?
Not sure if you have done this but you need to remove tension from the spring with a jack and a piece of wood as to not damage the spring. Align your spring bolt and torque the nut up a few inches. Then put the car back on the ground. You will need to roll the car back n forth about 20 ft to settle the IRS. Then make your height adjustments with the spring bolt. It will all fall into place once car is back on the ground.
Old Jul 22, 2010 | 11:04 PM
2box's Avatar
2box
Yes and about all the threads I still have to go from the bottom up so that the bushings fall in place and stay there once I drop the car.
Old Jul 22, 2010 | 11:39 PM
eastltd's Avatar
eastltd
Something seems strange with your set-up.
I have 10" bolts in mine and I had to jack the spring up to meet the bolts.
Maybe I goofed?
Old Jul 22, 2010 | 11:45 PM
2box's Avatar
2box
Maybe I goofed?
That is what I am thinking too. I will post a couple more pics. Maybe somebody can let me know......
Old Jul 23, 2010 | 12:18 AM
KanuckZ06's Avatar
KanuckZ06
I've just finished installing rebuilt trailing arms and a VPB glass spring on my 69 vert. I did not have to jack up the spring to install the spring bolts as well, just spin the nut on about 3/4" of an inch until you get the car on the ground, and set your height after the suspension settles.
Before doing anything, make sure you have clearance between your tires and fender lip when the car is off the jack stands!
When using the adjustable strut rods, set the cam bolts to the flatess setting, the idea is to get the half shafts as level as possible, before setting up the rear end alignment.
The only item of notice in your pictures is the adjustment of your strut rods, they are adjusted to far in.
I'll try and post some pictures next day of my car, so far it looks like your're doing a great job!
I've enjoyed working on my cars suspension system, you can really see the progress and take the satisfaction that its going to better than it was when it was new!
To rear susp. pic. help needed
Old Jul 23, 2010 | 12:38 AM
2box's Avatar
2box
Your help is greatly appreciated. Finally I hear of somebody that has gone through the same situation and it really conforts me to know I am on the right track. If You can post some pics I will appreciate it. I am trying myself to post a couple more so that anybody can see clearly what i am talking about... Thanks a lot..
Old Jul 23, 2010 | 01:09 AM
Frogday's Avatar
Frogday
You didn't happen to leave out the spacer that goes between the spring and the differential cover, did you? I have a TRW spring on one of mine and the spacer moves the spring down about 1" from the bottom of the diff cover - that would take up another 1" of the bolt.
This is the only photo I have handy that shows the spacer
You can see the slack on the bolts prior to setting the car down
Your bolts have a lot of thread on them, so once you get the height set right I'd cut them off to leave about 1/2" exposed beyond the nut if they are still long.
Old Jul 23, 2010 | 01:41 AM
2box's Avatar
2box
[QUOTE=Frogday;1574784382]You didn't happen to leave out the spacer that goes between the spring and the differential cover, did you? I have a TRW spring on one of mine and the spacer moves the spring down about 1" from the bottom of the diff cover - that would take up another 1" of the bolt.
I took the steel spring out and went with fiberglass and the old one did not have a spacer and the new one did not come with one. The instructions and diagrams for the install do not show or says anything about the vbp leaf needing a spacer. Thank You ....
