3rd gear muncie problems
Old Jul 27, 2010 | 11:43 PM
corvetteman72's Avatar
corvetteman72
Default 3rd gear muncie problems
Hey guys, i have a 72 corvette with a muncie m20 and i'm having issues. Not every time but usually when shifting into 3rd gear it will pop out. Also when im just in third gear or even when downshifting to 3rd it will pop out. I installed a hurts shifter and have adjusted the 3rd gear stop multiple times to check if that was it. Still doing it. Also i made sure the pedal adjustment was correct, don't know if it had anything to do with it or not. I have no idea what to think now. Im only guessing that maybe the syncro is bad. I'm clueless. This is my first post, If anyone has any input that would be greatly appreciated. Thanks
Old Jul 29, 2010 | 04:56 PM
corvetteman72
Old Jul 29, 2010 | 07:31 PM
Chuck72's Avatar
Chuck72
Default Welcome!!
Welcome!
Start with this:
http://forums.corvetteforum.com/c3-t...ggestions.html
Popping outta gear is, generally, a worn hub and/or slider. The splines are no longer parallel, so the slider backs away from the gear and disengages. As other members suggest, though, start with the simple stuff, b/4 you go plowin' through your tranny.
There is a search function in the red header bar,...great thing.
The search function is your friend!!
Regards,
Chuck
Old Jul 29, 2010 | 07:36 PM
Chuck72's Avatar
Chuck72
Also, you might consider filling your profile out. The vast majority of folks here are more than happy to give a hand. Most all work for beer!
You never know, you might be very close to competent, friendly help.
Chuck
To 3rd gear muncie problems
