under car heat shields
Old Aug 15, 2010 | 02:55 PM
baxsom's Avatar
baxsom
Default under car heat shields
I saw a picture of the underbody of a car with metal heat shields under the floorboards. I was wondering if those were oem or home made?
Old Aug 15, 2010 | 03:46 PM
la80vette's Avatar
la80vette
It depends on the year. The OEM shield are for the cats, footboard area and some under the differential.
Stephen
Old Aug 15, 2010 | 04:25 PM
oldsarge's Avatar
oldsarge
My 73 has a heat shield at each side of the engine, at the front sloped area of the floor boards, which is stock for most years of that era. If that is what you mean.
Old Aug 15, 2010 | 04:29 PM
7T1vette's Avatar
7T1vette
Early C3's had "rock" shields. They did little [if anything] to prevent heat from exhaust system.
Old Aug 15, 2010 | 07:36 PM
Duke94's Avatar
Duke94
My 71' has them, 78' doesn't. I agree with 7T1vette, rock shields as they don't do squat for heat.
Gary
Old Aug 15, 2010 | 07:54 PM
rcread's Avatar
rcread
My '71 has them as well, from the factory. Definitely not for heat.
Old Aug 15, 2010 | 08:16 PM
MyRed69's Avatar
MyRed69
My 69 has them (in a box right now). Guessing it'll help protect the fiberglass floorboard from rocks but not much of a heat shield.
Old Aug 15, 2010 | 08:20 PM
baxsom's Avatar
baxsom
Rock shields huh, Ok. I wonder if a layer of insulation can be put in between the shield and the floor board. Im trying to do heat control without pulling the carpet right now.
Old Aug 15, 2010 | 09:10 PM
7T1vette's Avatar
7T1vette
The only way to insulate for heat is to put a heat insulator under the carpeting. The sound deadener material will quiet your ride, but it won't reduce the heat [although it may slow it down a bit].
Old Aug 15, 2010 | 09:21 PM
baxsom's Avatar
baxsom
Ok not sure where sound deadner came from. I was thinking of putting a layer of heat insulation between the floorboards and the rock shield. As long as its between your feet and the exhaust pipes does it really need to be under the carpet.
Old Aug 15, 2010 | 09:41 PM
Farmer Dill's Avatar
Farmer Dill
Cruising
Just did my 68 w/ side pipes.I first wrapped the E pipe from the manifold back to the muffler as it went right below my feet and was terrible. I the got self sticking heat reflective material and stuck it directly to the floor boards from underneath between the rock shields and the floor. The previous owner fastened insulation to the top side of the shields which left a gap and air space between the insulation and the floor and it didn't do squat for heat reduction. Don't forget to put heat shield over top of transmission as there is also a lot of heat transfer from it. I would safely say this method reduced my heat problem by 50 to 60%.
Old Aug 15, 2010 | 09:52 PM
PUNISHER VETTE's Avatar
PUNISHER VETTE
My 69 has them and all i hear when at a stop light is one of those darn things rattling.
I haven't had time to mess around in that area yet but I'm pretty sure i saw one was attached with a zip tie....
Are these shields really needed? I'd like to lighten the car up as much as possible if i can eliminate them. Maybe i can spray some undercoating on the bottom of the fiberglass to help with the rocks?
Old Aug 16, 2010 | 06:46 AM
weinh's Avatar
weinh
My 69 has the rock shields as well and in addition the factory type heat insulation between them and the floor boards
In addition I did install under carpet insulation for coolest possible driving without A/C
Carsten
Old Aug 16, 2010 | 09:03 AM
TimAT's Avatar
TimAT
Carsten
My 69 has the same insulation under the rock guards. I have the tunnel insulation, but it's not installed.
Old Aug 16, 2010 | 10:01 AM
noonie's Avatar
noonie
My 77 came with no shields, but a metal floorpan with the angled firewall still being glass. Pass side had a hole it in from something thrown up.
To under car heat shields
