How do you know when your throw out bearing is going bad? When I press the clutch ('79, L82 4 speed) slightly you can hear the bearing engage with a whirring noise. The noise stays with the pedal all the way down to the floor. You can feel a light vibration in your foot and hear the whirring with your foot to the floor. It's not a whine sound, though.
... or is this normal?
I'm sure the bearing is original. The car has 11,500 miles on it. However, the clutch is solid every time it engages.
sounds like you are going to need to replace that sooner instead of later
when they make noise and vibrate they will last a little while
beware of damage to other things it may cause if you dont replace
k
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Don't worry about it till it blowed up real good, not to say don't take care of it before it blow, if it's a throwout bearing going south it will get worse and worse but still not a major repair
If you can already feel a vibration caused by the bearing I think it's time for a replacement.
11k miles is pretty low for that kind of failure though...
That's what I was thinking... replace it sooner rather than later. I guess that means an entire clutch kit since it is a pain to pull out the tranny & clutch anyway? (while I'm in there)
I would keep driving and monitor it's behaviour. With such low mileage, it may actually smooth out with more frequent use. Doubt it will suddenly let go on you ..........
At 11k miles, the clutch *should* have plenty of life left unless you drive the car really hard... but it is a 'vette, so you may just do that. Can you vouch for the 11k miles and how the car was driven?
Not to hijack the thread (okay maybe a little) but if I undertstand this correctly, clutch noise that picks up when you depress the clutch is caused by the throwout bearing? What causes clutch noise when the clutch is out and the car is in neutral? Thanks.
Any thoughts? Thanks.
The throwout bearing should not be spinning or whirring when the clutch pedal is out; in fact, there should be approximately 1 1/4" of pedal travel before the TO bearing contacts the clutch pressure plate fingers which will cause it to start spinning when the engine is running.
The typical problem of a bad TO bearing is that if it is spinning and loses lubricant, the lube will contaminate the clutch disk and make it grabby and judder during start up.
If your clutch still operates normally, just ensure that the proper freeplay exists and check it every 10k miles or so because as the disk wears, the freeplay will become smaller until there isn't any - and that's bad for clutch life.
My 79 L-82, M21 T.O. bearing-not original- started to make a howl under those operational procedures in cold weather at around 70K miles. It would stop after a short warm up. I waited it out and it quit on it's own. Hasn't made a sound for at least 10 years. I vote to monitor and replace if it gets really bad-it is a lot of work and at 11k is barely broken in. Good luck.
If the bearing wore out that quickly, (1) it could have been a defective bearing; (2) the clutch pedal could have been adjusted improperly (not enough 'slack' in the pedal when not applied; or (3) you have a habit of "riding" the clutch pedal when driving, instead of fully releasing it.
I appreciate everyone's inputs here.
I was thinking the TO bearing had lost its lube or dried out just sitting there most of its 31 year life (not being used). But maybe not?
larrywalk: There is no noise when the clutch pedal is out (clutch fully engaged). The clutch grabs solidly, consistently. The whirring (like a dry bearing sound) starts when you put your foot on the clutch pedal slightly and begin to depress it. I don't think it has a 1 1/4" of slack before the TO bearing begins to spin (and the whirring noise begins). More like 1/4".
7T1vette: Is that also what you mean by "not enough slack in the pedal when not applied?"
Does something need adjustment? If so, what/how do you adjust it?
My 78 L-82 4 speed has done that on and off for 27 years! Leave it alone or try the Wilcox adjustment above. I have never touched mine and have 65,000 miles on the clutch and engagement is perfect, just the whirring noise occassionally when hot. I had a couple of friends 20 years ago both with a 74 L-82 4 speed and another with a 79 L-82 4 speed bought new-both made the whirring noise when the clutch was engaged. Just monitor it and drive the car. Hope that helps!
Just push with your hand. You know about how much 5 pounds is (weight of a sack of sugar...oops! That dates me...they are 4 pounds now). Or, if you think in 'metric', a little more than 2 kilos. You just want to take the 'slack' out of the linkage and make contact with the T/O bearing.
I finally got around to adjusting it. The X distance of .4 (.4"?) seemed like it put too much free pedal travel in the pedal and the clutch engaged right off the floor. So I reduced X to about 1/4" (before it was zero). This seems perfect.
No whirring noise when the pedal is pressed slightly (unlike before) in the free play range (about 1"). Clutch engages nicely at appropriate distance from the floor. I'll run with it.
This was a piece of cake to do from the area right below the brake fluid reservoir with a 9/16" long socket and 9/16" wrench. Thanks, everyone, for the fantastic inputs!
