Coolant Expansion Tank
Old Aug 16, 2010 | 11:54 AM
jtramont's Avatar
jtramont
Default Coolant Expansion Tank
Hi guys...dumb question #148
If you pull the cap on the radiator coolant expansion tank, is there a hose that connects to the inlet? I had to replace my cap (it cracked) and in the process found that the inlet tube on the inside which points down was broken off. (Which is probably why the tank is full and the radiator way down.)
I checked the shop manual as well as the assembly manual and of course they were wildly helpful . As I read through the shop manual it says that for cars with the expansion tank the coolant level should be filled half way with the engine cold. The reason for my question is that while I realize that the coolant will expand and fill the tank, the downward inlet tube on the cap will be far from the mid point in the tank. Since it's not a sealed system, I wondered if there was supposed to be a rubber hose from the cap to the lower end of the tank.
Jim
Old Aug 16, 2010 | 12:17 PM
Carlos840's Avatar
Carlos840
There should be one hose going from cap to bottom of the tank and a second hose going from cap to out of the tank in case of overfill.
Old Aug 16, 2010 | 12:26 PM
Mike Ward's Avatar
Mike Ward
Might also be helpful if you told us what year car you're working on and what engine it has. Your profile is also blank.
Old Aug 16, 2010 | 12:30 PM
jtramont's Avatar
jtramont
Thanks and sorry guys...1973 with the L82 engine.
I'll try to get my profile updated soon. Between work, vacation, getting one kid off to college and moving the other one who's graduating it's been CRAZZZZZZZZZZZZZZY!
Old Aug 16, 2010 | 01:05 PM
Mike Ward's Avatar
Mike Ward
Ah- the proper name is a coolant recovery tank. Expansion tanks were on '72 and prior.
There is supposed to be a long rubber tube attached to the inside of the cap which reaches the bottom of the tank. The hose has probably fallen off and is sitting on the bottom.
The correct fill level for the tank is NOT halfway when cold- that's for expansion tanks. There are marks molded onto the side of the tank that indicate correct cold and hot levels.
Old Aug 16, 2010 | 01:16 PM
jtramont's Avatar
jtramont
Mike, thanks for the clarification and education. I came from an old MOPAR world where it was simply the radiator overflow bottle.
Old Aug 16, 2010 | 04:00 PM
oldsarge's Avatar
oldsarge
Old school, tech., we called it "puke tank"
I think in those years, there was also a screen bell type attachment, at the bottom of the tube.
Old Aug 16, 2010 | 04:17 PM
Alan 71's Avatar
Alan 71
Hi Sarge,
Learned somthing!!!
I knew of the screened bell at the end of the feed hose in my washer bottle, but didn't know it appeared elsewhere.
Richard Fortier, (Mr. Paragon), reproduces the screen for those looking for the final NCRS point.
Regards,
Alan
Old Aug 16, 2010 | 04:27 PM
Mike Ward's Avatar
Mike Ward
The reason for the nit-picking is some pre-'73 Corvettes had a pressurized external expansion tank with an integral radiator cap. This was used in conjunction with a stacked plate aluminum Harrison radiator.
Bubba has been at many of these cars overs the years and added all sorts of weird and wonderful 'upgrades'.
Old Aug 16, 2010 | 07:45 PM
gbvette62's Avatar
gbvette62
And the year also needs to be known because 73-77E had an expansion tank where the hose from the radiator attached to the cap. The Late 77-82 tanks have a solid cap and the radiator overflow hose attaches directly to the tank.
I've never seen a filter on the hose in the expansion tank, only on washer tank pick up hoses. With the crap and garbage that ends up in radiator fluid, a filter would always be clogged up, preventing coolant from returning to the radiator.
Old Aug 16, 2010 | 09:17 PM
Mike Ward's Avatar
Mike Ward
Same here. No filter in the expansion tank.
To Coolant Expansion Tank
