81speedo
Old Aug 21, 2010 | 08:59 PM
chuck swartzbaugh's Avatar
chuck swartzbaugh
Default 81speedo
1981 vette speedo jump up &down till i reach 35mile & hour can you help me chuck put in title 81 speedo
Old Aug 21, 2010 | 10:58 PM
terry82's Avatar
terry82
your speedo cables need lubed.
Old Aug 22, 2010 | 08:03 AM
manfroni's Avatar
manfroni
mine too, how do you lube the cable?
Old Aug 22, 2010 | 08:17 AM
LannyL81's Avatar
LannyL81
Remove the tack / speedo unit from dash. This exposes the end of the speedo cable....apply drops of light weight oil and let it run down inside the cable sheath. Going to take several hours for the oil to flow inside....take your time.
Old Aug 22, 2010 | 08:56 AM
damoroso's Avatar
damoroso
If you have cruise control, you can also break it loose there, and oil it. It's easier than getting at it under the dash!
Old Aug 22, 2010 | 09:16 AM
larryg3's Avatar
larryg3
much easier
Old Aug 22, 2010 | 10:33 AM
terry82's Avatar
terry82
they make lubes for speedo cables .i use white lithium grease.http://www.mamotorworks.com/corvette?frame=4.1170
Old Aug 22, 2010 | 11:33 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You guys might want to take a loot at this about speedo cable lubricant. (s)
While they can and often do solve your bounce problems the residual long term effects are negative.
http://willcoxcorvette.com/repairand...lp.php?hID=283
As one that rebuilds Speedo's and Tachometers, I've seen the results first hand! The cable is reverse wound and it will pull the grease in to the head! Once the grease begins to accumulate it will also attract dirt and dust and eat away at the first worm and magnet bushing.
Willcox Inc.
Old Aug 22, 2010 | 03:00 PM
jr105's Avatar
jr105
If you are going to the trouble of mucking around under the dash getting the cable disconnected from the speedo, just replace it. They aren't expensive and the most difficult part of the replacement is getting at the back of the speedometer. I tried lubing mine and it lasted a couple of months before it started bouncing again. I wound up replacing it and wishing I had just done that in the first place.
Old Aug 22, 2010 | 03:11 PM
terry82's Avatar
terry82
most cables that go bad are between the transducer and the transmission.
Old Apr 12, 2011 | 09:15 PM
tyancey00's Avatar
tyancey00
anyone have a diagram for transducer to the trans?
To 81speedo
