HELP A/C quit
Old Sep 5, 2010 | 09:18 PM
Tom68's Avatar
Tom68
Default HELP A/C quit
I drove my 68 last weekend stopped at the car wash. A/C was working fine got back in the car started it up nothing. No fan, no compressor,
nothing, does not come on when moving the controls from off to vent or A/C. It is dead! Where do I start to trouble shoot this system?
No, I did not wash the engine compartment.
Tom
Old Sep 5, 2010 | 10:28 PM
chvet73's Avatar
chvet73
I'm not sure if yours has the same fuse my '73 does. But near the horn relay is a 30 amp inline fuse. Often the issue when the whole system is down.
Old Sep 6, 2010 | 10:25 AM
Tom68's Avatar
Tom68
73, Thanks for the reply I found the fuse changed it still no power. So the search is still on looking for where to start.
Tom
Old Sep 6, 2010 | 11:06 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Tom-
I'll look at a schematic tomorrow for you.
Willcox
Old Sep 6, 2010 | 11:47 PM
CCrane65's Avatar
CCrane65
Just to clarify, the blower is not running correct?
I would check the blower speed switch, the resistor and the HTR/AC fuse in the fuse block.
cc
Old Sep 7, 2010 | 07:32 PM
0Willcox Corvette
Former Vendor
No Compressor or blower.. I'd go to the fuse panel first.. just looking at the schematic it looks like the a/c harness plugs in to the accessory terminal... is it possible you booted it?
If not.. go to the relay and check the orange wire for power and trace the dark green wire from the compressor and look for power. It plugs in to the thermal switch and then runs to the inside of the car. But I'd sure make sure you don't have an issue at the fuse panel first. The wire is a 14 Brown.
Old Sep 8, 2010 | 08:37 PM
Tom68's Avatar
Tom68
Wicox, Thanks for the reply I don't have a schematic where is the relay you refer to?
Tom
Old Sep 11, 2010 | 09:01 PM
0Willcox Corvette
Former Vendor
High blower relay.. On the a/c plenum...
Willcox
To HELP A/C quit
