Throttle Cable sticking.. Please help
Old Sep 7, 2010 | 02:31 PM
capth4u's Avatar
capth4u
Default Throttle Cable sticking.. Please help
Hello everyone... I installed a new throttle cable and now it is sticking some.... Here are a few photos .... Is it because of the white tube looking thing in the second photo? Thank you
Adam
Old Sep 7, 2010 | 05:43 PM
TimAT's Avatar
TimAT
I don't see a return spring at the carb?
Old Sep 7, 2010 | 06:56 PM
ED79's Avatar
ED79
no spring
Old Sep 7, 2010 | 07:58 PM
mar's Avatar
mar
Default ...like this...?
Isn't there usually 'two' springs - one inner and one outer???
Old Sep 7, 2010 | 08:03 PM
CFD E59's Avatar
CFD E59
Old Sep 7, 2010 | 08:19 PM
capth4u's Avatar
capth4u
The carb did not come with spring....
Old Sep 7, 2010 | 10:55 PM
Ray Y's Avatar
Ray Y
Nor did mine, you have to buy them seperately as far as I know, but you need one for sure.
Old Sep 7, 2010 | 10:56 PM
PRNDL's Avatar
PRNDL
The carb doesn't come with an accelerator cable either. You need the spring. In fact it is so important for the now obvious reason many use 2... just in case one breaks.
Old Sep 8, 2010 | 12:25 AM
7T1vette's Avatar
7T1vette
No spring... no return...
Old Sep 8, 2010 | 08:07 AM
capth4u's Avatar
capth4u
OK.. thank you .. Im guessing I can these springs at advanced auto parts or Napa? Thank you all again!
Old Sep 8, 2010 | 09:52 AM
mar's Avatar
mar
Advance? Probably not. NAPA - probably, yes.
Old Sep 8, 2010 | 11:06 AM
7T1vette's Avatar
7T1vette
You can buy springs at any car parts store. You likely can NOT buy the correct spring(s) for it, though. If you want to keep the car 'correct', buy a "temporary" spring at a local store and order the correct one from a Corvette parts supplier.
Old Sep 8, 2010 | 08:33 PM
capth4u's Avatar
capth4u
So where do the springs hook on exactly? I bought Mr Gasket set of spings with a clip L bracket. I hooked the springs onto the bottom of the carb and the the L bracket I installed on to my throttle bracket. Ill have a photo tomorrow to post. Thank you all !
Old Sep 8, 2010 | 11:41 PM
TimAT's Avatar
TimAT
As long as the spring is pulling the throttle closed, it really makes no difference which direction it's pulling.
One thing you don't want- too much tension on the spring will not only make it hard to push the go pedal, but it'll wear the throttle shaft in the carb too. It won't happen instantly, but you will get a weird, hard to find vacuum leak.
Old Sep 9, 2010 | 12:38 AM
jordan89's Avatar
jordan89
Old Sep 9, 2010 | 01:23 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Driving a car with no return spring is a BIG danger, don't drive it anywhere unless you put a return spring there.
Old Sep 9, 2010 | 10:57 AM
mar's Avatar
mar
Refer to my photo above - it's pretty intuitive. It's an easy job.
Old Sep 22, 2010 | 11:22 AM
capth4u's Avatar
capth4u
Will this "L" bracket work ok? I just would hate for the screw to fall out... I do see two holes on the throttle bracket (see second photo) to hook the spring but they are very close to the carb.... I would have to use shorter springs. What do you think?
Old Oct 31, 2015 | 06:49 AM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
On a stock '71 350/270, does the throttle cable go on the inside or outside of that left tower that supports the chrome distributor cover?
To Throttle Cable sticking.. Please help
