Idle stop solenoid
Old Sep 9, 2010 | 10:09 AM
mlibhart's Avatar
mlibhart
Default Idle stop solenoid
74 big block 454 with stock Quadrajet. Can someone tell me the function of the idle stop solenoid mounted on the throttle side front corner of the carb? Also, how to correctly test the solenoid for functionality?
Old Sep 9, 2010 | 10:48 AM
ED79's Avatar
ED79
It is used to increase your rpm's at idle when the a/c is on.
The wire from the solenoid runs to the a/c compressor, when a/c is turned on while idleing your rpm's will drop, with the breather off (better to see) when you increase the rpm's you will notice the solenoid piston extend outward to hold the linkage at a higher rpm, hope this helps. Ed
Old Sep 9, 2010 | 11:49 AM
7T1vette's Avatar
7T1vette
The '74 version may be different from my '71 (w/ac), but the idle stop solenoid is NOT used to prevent dieseling on mine. The idle stop solenoid is used to reduce idle speed when in upper grear ranges at closed throttle and to set a curb idle speed. The anti-dieseling function (on A/C cars) is a 3-second timer which sends power to the A/C clutch when the engine is turned off. The extra load from the compressor prevents engine run-on.
Old Sep 9, 2010 | 01:20 PM
Mashman's Avatar
Mashman
The solenoid on the carb that when energized bumps the accerator lever, is commonly called the idle stop solenoid.
In early years this solenoid is energized whenever the ignition is on. It is deenergized when the ignition is turned off, and is used to stop engine desieling.
In later years, it was tied to the A/C system, and was also used to bump up the idle speed when the A/C compressor was running - I believe this was to help with engine cooling when idleing.
In 71, there was a 1 year only CEC system. The CEC (Combined Emissions Control system) solenoid replaced both the TCS solenoid (used in 70 and 72), and the idle stop solenoid. More info can be found here - start on page 5. http://ncrsrmc.org/Downloads/Mar-2006-Newsletter.pdf
To know exactly how it was used in 74, I believe you will need to either look in a 74 service manual, or find out from someone with a correctly functioning 74.
Old Sep 9, 2010 | 04:00 PM
7T1vette's Avatar
7T1vette
Interesting. Thanks for the clarification.
Old Sep 9, 2010 | 05:05 PM
ED79's Avatar
ED79
Thanks Ed
Old Sep 9, 2010 | 09:58 PM
mlibhart's Avatar
mlibhart
Thanks all for your input! It appears to be setting idle stop only and closing the butterfly when engine is off (to prevent dieseling). I placed a 12v jumper on it tonight and the plunger reacted immediately just as it should. (One less part to replace )
To Idle stop solenoid
