72 Vacum problem
Old Sep 9, 2010 | 09:48 PM
prg1969's Avatar
prg1969
Default 72 Vacum problem
Need some help, headlights and wipers work fine but I have a line off under the dash and I don't know where it goes. The hose comes off a small vacum canister that is on the right side of the steering colum, there is also a electrical hook up to the canister. Little help please.
Old Sep 10, 2010 | 12:33 AM
DZRick's Avatar
DZRick
This should help you, although if you have a vacuum hose that is not hooked up I'm wondering how it is that everything works.
Old Sep 10, 2010 | 11:20 AM
Mashman's Avatar
Mashman
Do you feel air coming out the top center of the dash pad when the defroster is on? What about with the defroster off?
Old Sep 10, 2010 | 02:13 PM
thatcorvetteguy's Avatar
thatcorvetteguy
It sounds like someone put a hose on the vent side of the wiper solenoid????
Old Sep 11, 2010 | 01:40 AM
prg1969's Avatar
prg1969
When I pull on the light switch, lights open and operate fine, to operate wipers I have to pull the the small post below the dash than the wiper door opens and I can turn on the wipers with the switch, should the wiper switch be like the lights? Turn the wiper switch on and the door opens and then wipers come on? From the picture the device that looks most similar is the small unit with the green and red line coming of it or it could be unit the has black line from switch and yellow out. Thanks for your help with this stuff.
Old Sep 11, 2010 | 01:46 AM
prg1969's Avatar
prg1969
To you others that helped, defroster seems to work as normal, but I will have a pay more attention when I check it tomorrow.
If I know how to identify the wiper solenoid I could check, Just got this car and I am trying to figure out all the various vacum operations. I am thinking of buying the manual for trouble shooting vacum problems.
Old Sep 11, 2010 | 03:17 AM
thatcorvetteguy
The wiper door should open and close from the wiper switch on the upper dash.
Old Sep 11, 2010 | 09:12 AM
DZRick's Avatar
DZRick
Here's the wiper solenoid.
I marked the hose colors based on Willcox's diagram and the factory paint mark seen in my picture.
If this is hooked up correctly and in good working condition the wipers should work without touching that over-ride switch assuming all the other components of the wiper system are in good shape.
I think both Dr. Rebuild and Willcox have troubleshooting diagrams.
Well that didn't work out very well!
Where my thumb is, is where a little foam filter should be. Don't be surprised it that is missing but it wouldn't be a bad idea to replace it if it is.
The hose connection pointing to the right should have the blue striped hose, the one pointing up gets the yellow striped vacuum hose and the wires land up top too.
This solenoid was mounted to the backside of the tachometer from the factory.
Old Sep 11, 2010 | 11:10 AM
prg1969's Avatar
prg1969
I just looked, the foam filter is there and the disconnected hose is coming off the side port, but there is no hose attached to the brass end of the solenoid but the wires are attached. In the drawing, where is the yellow line going to, I can't tell what that is.
Old Sep 11, 2010 | 11:31 AM
DZRick's Avatar
DZRick
The yellow striped vacuum hose goes from the wiper solenoid to the headlight switch. That is the headlight switch at the upper right-hand corner of that diagram.
Old Sep 11, 2010 | 01:39 PM
prg1969's Avatar
prg1969
Why does mit go to the headlight switch?
Old Sep 11, 2010 | 03:41 PM
DZRick's Avatar
DZRick
I should have said it tees off with one hose going to the headlight switch.
The headlight switch and the wiper door share the same vacuum source.
If you look at the diagram you'll see that the vacuum source (that's at your intake manifold) shown as black, it goes through a filter, then a check valve. From the upper port of the check valve it heads in under the dash where it hits a tee. One side of the tee ( shown in yellow ) goes to the solenoid, the other ( shown as black ) goes to the headlight switch.
Study the diagram, you'll see how everything is supposed to be hooked up. As far understanding completely what does what and when, well...
Old Sep 11, 2010 | 03:45 PM
prg1969's Avatar
prg1969
ok thanks for your help
To 72 Vacum problem
